How many conversions have heat?, stock or otherwise |
moparrob |
Jan 5 2012, 12:23 AM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
I'm going with headers on my 6 and am not as concerned about heat (in So. Cal.) as I am about defrosters.
I need to find an interesting 12v solution that I can rig into my defroster vents. Maybe some 12v travel hair dryers or the like? (IMG:style_emoticons/default/confused24.gif) |
phillstek |
Jan 5 2012, 12:54 AM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Heat is for pussies (IMG:style_emoticons/default/stirthepot.gif) Same for air conditioning and stereos. Dress appropriately and the sound of the six is music enough for my ears.
phil |
Stonepilot |
Jan 5 2012, 07:03 AM
Newbie Group: Members Posts: 20 Joined: 6-December 11 From: Pensacola, Florida Member No.: 13,863 Region Association: South East States |
My only concern would be defrosting my windshield, how do you do it without a heater
dion9146 |
Jan 5 2012, 07:22 AM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
The last time my windshield attracted moisture was during a night time autocross in the rain in 1994, and that was also my first 914. It was also the last time I purposely drove a 914 in the rain. A rag did the trick.
Jan 5 2012, 07:39 AM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The last time my windshield attracted moisture was during a night time autocross in the rain in 1994, and that was also my first 914. It was also the last time I purposely drove a 914 in the rain. A rag did the trick. Your talking about defogging the windshield. You need heat to defrost the windshield when it's below 32. Without heat, you have to drive with the fan blowing or windows open to keep the windshield from frosting up inside. Brings back memories.... The right price cures everything. |
dion9146 |
Jan 5 2012, 08:16 AM
defog, defrost, I still don't drive it in the weather you are describing. And you know what, in my opinion that is a positive.
Let's not let the price of my car enter into the equation here. |
jim912928 |
Jan 5 2012, 08:58 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
well...here in Wisconsin if you are driving in "nice dry weather" in late fall or early spring where the roads are nice...you have issues with the window's fogging in early morning or at night. Heat is required unless you are only driving during the day. Or you are constantly wiping the inside of the windshield with a rag...been there, done that...and it's too scary.
ClayPerrine |
Jan 5 2012, 10:42 AM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I can't find the link right now, but aircraft spruce makes heater boxes to clamp around headers to provide heat.
Jan 5 2012, 10:55 AM
I can't find the link right now, but aircraft spruce makes heater boxes to clamp around headers to provide heat. http://www.aircraftspruce.com/catalog/eppa...rsheatmuffs.php Doesn't look like there will be enough volume to really heat up car but it would be great if it works! You need 12" of straight pipe on the header. Don't know if our cars have that available? Attached image(s) |
ClayPerrine |
Jan 5 2012, 10:59 AM
I can't find the link right now, but aircraft spruce makes heater boxes to clamp around headers to provide heat. http://www.aircraftspruce.com/catalog/eppa...rsheatmuffs.php Doesn't look like there will be enough volume to really heat up car but it would be great if it works! You need 12" of straight pipe on the header. Don't know if our cars have that available? Behind the collector? It would probably work fine. Beats nothing at all. |
dion9146 |
Jan 5 2012, 11:07 AM
I've seen these too. They would probably interfere with the O2 sensor installed on my header.
Ericv1 |
Jan 5 2012, 07:14 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
I can't find the link right now, but aircraft spruce makes heater boxes to clamp around headers to provide heat. http://www.aircraftspruce.com/catalog/eppa...rsheatmuffs.php Doesn't look like there will be enough volume to really heat up car but it would be great if it works! You need 12" of straight pipe on the header. Don't know if our cars have that be available? That is a great idea. If it heats up the cabin of a small aircraft, it should work for our cars. It wouldn't take long to heat up for such a small area and they are relatively inexpensive compared to the alternative. |
914dave |
Jan 9 2012, 10:51 AM
914 Addict Group: Members Posts: 703 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Putting GHL exchangers on my conversion. It extends the driving season and helps defrost. Still don't/won't drive after there's salt on the roads. Have a heated blanket for the passenger.
pcar916 |
Jan 9 2012, 11:59 AM
No category for my heat in the pole.
I have a large front oil cooler that operates all the time (when >180F) and block off ~20% of it when the weather gets cool. It takes about 20 minutes to install or remove the entire system. The rest of the year It hangs on the wall. I got the idea from JT9146 who did this with his car. The only real differences were that his cooler was an auxiliary rather than the primary, and it was completely vented. I'm out of state but will add pix when I get back home. A bilge fan with speed control and hoses through to the stock heater inputs makes plenty of hot air for both defrost and heater controls to regulate. In the south with our moisture we need defrost at temps way above freezing. Even Clay would stay warm! |
ape914 |
Jan 9 2012, 01:52 PM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
A gasoline heater like found in the old VW campers would work great in a 914, some were even sold ducted for 914's Any VW camper heater could be ducted to work in a 914. make sure you get a 12 volt version, not a 6 v.
Lo-Fi Version | Time is now: 9th June 2024 - 03:28 AM |
