New circlips for AA's 96mm pistons |
yeahmag |
Jan 7 2012, 10:48 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'd like not to reuse the circlips in my rebuild. I've called AA and they unfortunately haven't gotten back to me even after speaking to a sales rep. Are there anything special about these or can I order something of the same size and run with it?
TheCabinetmaker |
Jan 7 2012, 12:38 PM
they should have came with the piston set.
Valy |
Jan 7 2012, 12:39 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I'd like not to reuse the circlips in my rebuild. I've called AA and they unfortunately haven't gotten back to me even after speaking to a sales rep. Are there anything special about these or can I order something of the same size and run with it? Almost anything will work as long as it's the right size. There isn't too much lateral pressure on the clips. Type 1 had a wire clip. |
Jake Raby |
Jan 8 2012, 01:16 AM
I disagree.. At BDC and TDC changeover the pins are loaded laterally.
Use proper fitting clips in both diameter and thickness or you will have a bad day. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:22 AM |
