Epic 914 story, For every high there's a low |
xsJerry |
Jan 15 2012, 07:14 PM
Newbie Group: Members Posts: 44 Joined: 26-November 11 From: Arcata, CA Member No.: 13,822 Region Association: Northern California |
My three moth quest for a teener finally ended yesterday when I purchased a very nice well sorted out 75 5.7 conversion. The drive home from the bay area to Arcata was to be 250 mi of mostly freeway, and by the time I reached Mendocino co. it was running so good I decided to take a twisty 144 mi rout through the Mendocino coast
This was the most fun i've had in a car ever...until, while running hard though the corners, I heard a clunk, some grinding, and thre was to power to the wheels. Now I'm in the tow truck on my $700 trip home. I like the car so much, and the deal was so sweet, I'm still happy I bought it. I may be singing a different toon once I get into the trany (I expect thats the issue) |
brant |
Jan 15 2012, 07:21 PM
I'm betting you lost a CV rather than a tranny
tell us the symptoms more descript. did you look underneath while waiting on the tow truck? sorry about the incident but cool that you like the car! |
ottox914 |
Jan 15 2012, 08:02 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I popped a CV a an autocross with much the same symptoms. If thats a 5.7 conversion with the OEM axles, you very well may have an easier fix than you think...
Congrats on your new ride. How about some pics? |
xsJerry |
Jan 15 2012, 08:24 PM
I popped a CV a an autocross with much the same symptoms. If thats a 5.7 conversion with the OEM axles, you very well may have an easier fix than you think... Congrats on your new ride. How about some pics? OK, I just got dropped off by the tow truck, I was having trouble attaching pics from my iPhone, so here's some pics. I don't believe the axles are stock, and I couldn't see anything amiss under the car, but I guess I'll find out when I get it on a lift. And yes, i should have known better than to flog the car on a 140 mi. of twisties ( i made it for a 132mi of it) until I had a chance to go over it, but i wasn't going to be able to drive that road until summer, so I took the opportunity. By the way, if you are in n. cali. highway 128 to fort bragg and then 1 to 101 is an epic drive for a 914. mine just loved it; until it didn't. Attached thumbnail(s) |
Dr Evil |
Jan 15 2012, 08:41 PM
Bet ya dropped the CV, like the others said (IMG:style_emoticons/default/smile.gif) Hope you did, its an easy fix.
Mike Bellis |
Jan 15 2012, 09:05 PM
I used to blow my CV's with my V8 so often, I kept a spare axle in the trunk. When you shift your car, let the torque settle for 1/2 second before you stmop on it. You can't drive it like a Camaro...
Easy Fix! Make sure you get the 12 point allen tool for the axle bolts. Do not use an incorrect tool, you will thank me. |
aharder |
Jan 15 2012, 09:17 PM
Advanced Member Group: Members Posts: 4,389 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Nice looking car (IMG:style_emoticons/default/biggrin.gif) Sorry to hear the bad news (IMG:style_emoticons/default/sad.gif) Be sure to update the data base (IMG:style_emoticons/default/beerchug.gif) |
Cairo94507 |
Jan 15 2012, 09:25 PM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
OK sorry for your misfortune but anyone with a 914 needs to have the AAA premium tow service. They will tow my car 200 miles, anywhere for free, 2 times per year. Cost me an extra $40 year above the standard service.
xsJerry |
Jan 15 2012, 11:38 PM
OK sorry for your misfortune but anyone with a 914 needs to have the AAA premium tow service. They will tow my car 200 miles, anywhere for free, 2 times per year. Cost me an extra $40 year above the standard service. I thought I had the 100mi service until I called AAA (almost exactly 100mi from home). I guess I learned a couple of lessons today. |
xsJerry |
Jan 16 2012, 12:03 AM
I'm betting you lost a CV rather than a tranny tell us the symptoms more descript. did you look underneath while waiting on the tow truck? sorry about the incident but cool that you like the car! I noticed a little whining (from the gearbox I think) on the freeway. Otherwise everything was fine. in the twisties, there was a couple of clunks and a rattling sound. I thought something was dragging on the road. I pulled off and then for some reason tried to move forward a little, there was a pronounced clunk, and that was it. I did look underneath while waiting for the truck and could nothing amiss. Everything look clean and new and unbroken. This is a bad sign isn't it? |
Cap'n Krusty |
Jan 16 2012, 12:18 AM
A CV joint can break and still not cause the boot the tear. st place I'd look. Jack up one side only, put the car in gear, and try to turn the wheel. If it won't turn, lower that side to the ground and repeat the test on the other side.
The Cap'n |
xsJerry |
Jan 16 2012, 06:14 PM
A CV joint can break and still not cause the boot the tear. st place I'd look. Jack up one side only, put the car in gear, and try to turn the wheel. If it won't turn, lower that side to the ground and repeat the test on the other side. The Cap'n Thanks Cap'n, i did it and found it was the CV, thank goodness. The car has the Renegade axle kit, so $130 for a bus CV, and I could be on the road tomorrow. of course there's all sorts of play on the broken side, but on the other side there's a fair amount of play side to side (see photo), is that normal? By the way, when I dropped the car off the jack (I used that funky thing on the rocker cover) the car stayed at an angle. When I released the e-break, it righted itself. For the life of me, I can't figure out why that is. it still looks less than level, but I haven't taken out a measuring tape yet. Attached image(s) |
PeeGreen 914 |
Jan 16 2012, 06:20 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Nice car (IMG:style_emoticons/default/beerchug.gif) I hope you are able to get everything sorted out easily.
brant |
Jan 16 2012, 06:48 PM
your car probably has delirin (aftermarket) suspension bushings put in by the previous owner
They tend not to settle and stick causing the car to remain jacked up a bit rather than settling on its suspension. this effectively changes the spring rate if they are dragging. I have them still on one car and used to have to remove the suspension annually and grease them to solve this problem. but its a pain removing all of the suspension and then going through the corner balance/alignment routine afterwards. I finally added zerks when they were apart and can keep them lubricated much easier now. the roller bearings are another solution, but more expensive. the factory suspension bushings didn't "turn" like all fo the aftermarket solutions do.... so the car wasn't really designed to have moving bushings. for now... drive it roll it bounce it and it will probably re-settle just know that you have more spring rate on one corner than others.... brant |
brant |
Jan 16 2012, 06:52 PM
oh hey...
buy brand new schorr washers for both sides (inner and outer) CV's... put NEW washers on all of the bolts (16 i think) and retorque them all that or drilling the bolts are REQUIRED your cage may have broke with all of that power... but you still run the risk of having a new one come loose if you don't put the new washers on. b |
76-914 |
Jan 16 2012, 09:06 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/happy11.gif) Sorry for laughing but it got me, too. The rear wheel is on an arm which compress' when the car is lowered. If the brake is set it will stand up until you release the parking brake. You'll also find that the drivers door and psg door lock differently and if you leave the turn signal in position after you park, your parking lite for that side only, come on. It's just begining.
ezbngreen914 |
Jan 16 2012, 09:20 PM
Member Group: Members Posts: 441 Joined: 11-December 10 From: Sautee, GA Member No.: 12,472 Region Association: South East States |
Mine on the way home the day I bought it. Fuel pump. I think its good luck if that happens* *good luck for the towing company (IMG:style_emoticons/default/happy11.gif) Looks like you got a great car! good luck! |
matthepcat |
Jan 17 2012, 09:56 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
That's one clean looking conversion. Have fun with it and if you pop the tranny, it's not the end of the world.
I am suprized that the bus cv popped! What are the motor specs? |
Andyrew |
Jan 17 2012, 10:20 AM
I was thinking to myself, How did he pop a CV so easily with a 1.8? then I noticed the pic of the header and the original post.. (IMG:style_emoticons/default/smile.gif)
Keep a spare cv in the trunk with the stub axle, Keep a breaker bar with the right socket (its like 1" or something) and then a smaller ratchet with the allen. You can change the CV on the side of the road in about 25 minutes assuming that you have broken loose the stub axle previously in the cars life. You pop the stub axle nut off, start loosening the allen bolts on the trani flange and roll the car forward to get all the bolts, then a screwdriver or even just your hands to push the cv up to separate from the trani and pull at an angle (might have to tap the stub on the outer side) and out pops the cv. Install is in reverse. |
rjames |
Jan 17 2012, 10:42 AM
I'm made of metal Group: Members Posts: 3,930 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Nice looking car. I like the later square fog lights with the early bumper.
Hope you get it back on the road soon. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 02:21 AM |
