914-4 front control arms VS 911 |
-JR- |
Jan 19 2012, 03:00 AM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I haven't had the opportunity to dismantle my front end... yet. I was under the impression that...
So the 911 arm is not identical to the 914. I see in PET that the part number for the 914-6 control arms match the 911. I'm posting it because a reliable 914 source locally has told me that they are interchangable (911 / 914-4) but I didn't believe so. Thanks to anyone who can clear this up. |
ClayPerrine |
Jan 19 2012, 07:35 AM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The only difference between a 914/4 control arm and a 911 control arm are the splines for the torsion bars. The 914/6 uses the 911 control arm, so it has the 911 torsion bars.
Other than that one item, they are interchangeable. I have 914/4 control arms on my car with 911 struts and a 911 aluminum cross member. No problems getting anything to fit. |
-JR- |
Jan 19 2012, 10:51 PM
The only difference between a 914/4 control arm and a 911 control arm are the splines for the torsion bars. The 914/6 uses the 911 control arm, so it has the 911 torsion bars. Not sure if this is splitting hairs, but the 914-6 tortion bar isn't the same as the 911. Yes it has the same size splines, but it has a lower torsion strength to acount for the lower 914-6 weight. Thanks everyone. for ringing in to. Looks like my local 914 guru's got it wrong. One last variant, I'm not sure any of us would see it, but apparently some 914-6 GT cars had torsion bars with different diameter splines at either end of the torsion bar. Not sure what the point was, maybe it was to save weight. |
SLITS |
Jan 20 2012, 07:55 AM
The only difference between a 914/4 control arm and a 911 control arm are the splines for the torsion bars. The 914/6 uses the 911 control arm, so it has the 911 torsion bars. Not sure if this is splitting hairs, but the 914-6 tortion bar isn't the same as the 911. Yes it has the same size splines, but it has a lower torsion strength to acount for the lower 914-6 weight. Thanks everyone. for ringing in to. Looks like my local 914 guru's got it wrong. One last variant, I'm not sure any of us would see it, but apparently some 914-6 GT cars had torsion bars with different diameter splines at either end of the torsion bar. Not sure what the point was, maybe it was to save weight. For racing purposes, the torsion bars would have a higher rate to control suspension movement / body roll when highly loaded as in a corner. Control of body roll is critical to maintaining the maximum tire patch on the road (minimize camber changes). And Andy, I read it as they wanted to stuff 911 torsion bars in a 914/4 control arm or visa versa. |
SirAndy |
Jan 20 2012, 12:23 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
And Andy, I read it as they wanted to stuff 911 torsion bars in a 914/4 control arm or visa versa. I didn't read it that way at all. (IMG:style_emoticons/default/confused24.gif) Well, English is not my first language, this must have been lost in translation. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 12:42 PM |
