Los Angeles: 75 Custom VW Street Bug - No Smog Required! (Pasadena (Kaddie Shack)) $5000 |
914World |
Jan 17 2012, 10:45 AM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
714-752-3766
Completely professionally re-done VW Standard Beetle (Not a Super-Beetle), inside and out, top to bottom. This car is "Turn-Key", ready to drive, and definitely a looker! It has been professionally customized to provide the very best in great looks, reliability, drivability, and mileage; while keeping it within an affordable budget. (IMG:http://i292.photobucket.com/albums/mm35/57baja/75BUG.jpg) (IMG:http://i292.photobucket.com/albums/mm35/57baja/IMG_0948.jpg) (IMG:http://i292.photobucket.com/albums/mm35/57baja/IMG_0947.jpg) (IMG:http://i292.photobucket.com/albums/mm35/57baja/IMG_0953.jpg) (IMG:http://i292.photobucket.com/albums/mm35/57baja/IMG_0949.jpg) (IMG:http://i292.photobucket.com/albums/mm35/57baja/IMG_0951.jpg) (IMG:http://i292.photobucket.com/albums/mm35/57baja/IMG_0950.jpg) (IMG:http://i292.photobucket.com/albums/mm35/57baja/IMG_0952.jpg) ENGINE SPECS 1600cc Performance modified dual port engine: o Dyno tested at 50% more horsepower than original at 5000 RPM (Actual Dyno Results Attached) o Kaddie Shack dual Kadron Carbs custom jetting, set-up, & installation o BRAND NEW 1.4:1 Ratio Rockers o BRAND NEW Hand-polished Scat dual-cam heim joint linkage -- Made In USA o BRAND NEW Fat Boy performance muffler o BRAND NEW Extractor exhaust system o BRAND NEW 36hp Style Fan Shroud o BRAND NEW Chrome oil filler/breather tower o BRAND NEW Scat chrome alternator stand o BRAND NEW Scat chrome alternator tin o BRAND NEW Rear breastplate, firewall tin, & oil cooler exit ducting o BRAND NEW Chrome distributor clamp & coil mount o BRAND NEW Air Cleaners o Refurbished aluminum intake manifolds o "AJ" '75 FI dual relief German case o Late model fuel injected cylinder heads & tins o Performance "009" style distributor o Late-model high-output alternator Before and after dyno tests of motor: (IMG:http://i292.photobucket.com/albums/mm35/57baja/dyno1-1.jpg)(IMG:http://i292.photobucket.com/albums/mm35/57baja/dyno2-1.jpg) TRANSMISSION SPECS - FREEWAY FLYER Transmission - Excellent mileage and reliability -- 3.88 R/P, Single Side Cover FEATURES, UPGRADES & MODIFICATIONS - BRAND NEW New 914 Porsche Style Alloy Wheels and chrome lug bolts - BRAND NEW 205/70 Performance Rear Tires (Maximum performance grip) - BRAND NEW 155/60 Performance Front Tires (Max safety & handling, great low-profile look) - BRAND NEW Dropped spindles -- lowered 2-1/2" in front while still retaining fantastic ride - GREAT working late-model dual circuit four-wheel drum brake system, recently serviced - CHERRY original front/rear seats with immaculate covers and cushions - CHERRY Re-upholstered quality headliner - BRAND NEW door and quarter panels - BRAND NEW interior sun visors - BRAND NEW Front cargo area carpet kit & spare tire cover/toolbag - BRAND NEW 6x9 Pioneer speakers with AIWA stereo unit - BRAND NEW Billet Running Boards - BRAND NEW Fuel hoses, fuel pump, and filler line - Tinted windows
Lo-Fi Version | Time is now: 19th May 2024 - 10:27 PM |
