Home made ultra-sonic FI cleaner |
Mark Henry |
May 1 2003, 05:37 PM
I had an old electric tool engraver lying around. I hose clamped the tip to nut and another hose clamp, and then I clamped it to a small Tupperware condiment container. I then put an injector in it and added FI cleaner till it just covered the injector.
Put on the top and plugged it in, it works great. I have cleaned a couple of injectors now including one with a seized pintle (sp?) that has now freed up. |
Mark Henry |
May 1 2003, 07:13 PM
Yep, wish I had a digi cam for this one!
You can't put a hose clamp on the tip of the engraver alone, too small, so I put the clamp around a nut and stuck the tip in a bit and tightened it up. At the same time, I also put another clamp through the nut clamp set up and that one went around the container nice and tight. It's working like a charm, you should see all the crap coming off of my injectors. BUT it is noisier then the morning after beer Schlitz!!! I turn it on, go in the house and turn on the stove timer for 30 minutes each, so I don't have listen to it. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:49 PM |
