Home made ultra-sonic FI cleaner |
Mark Henry |
May 1 2003, 05:37 PM
I had an old electric tool engraver lying around. I hose clamped the tip to nut and another hose clamp, and then I clamped it to a small Tupperware condiment container. I then put an injector in it and added FI cleaner till it just covered the injector.
Put on the top and plugged it in, it works great. I have cleaned a couple of injectors now including one with a seized pintle (sp?) that has now freed up. |
Lawrence |
May 2 2003, 08:48 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Mark,
Thank you for the visual with the last post... I get it. Very cool idea. Could one not attach the engraver tip to the injector? Too hard on the injector itself? Also, do you change the injector cleaner part way through the cleaning process? I would be concerned about cycling crap through the injectors. I bet there's gonna be a run on engravers on evilBay... -Rusty |
Lo-Fi Version | Time is now: 18th May 2024 - 11:48 PM |
