Starter rebuild |
Starter rebuild |
stugray |
Jan 24 2012, 12:15 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Ok, so during my 914 race car rebuild, I decided to test my starter using a battery charger.
I knew that "not spinning fast enough" wasn't a show stopper, but when the solenoid popped out the gear, but it wouldn't pull back in (on it's own)... that was a problem. So I decided to completely disassemble & re-grease/reassemble the whole thing. Here are some pics after a MAJOR cleaning with a lot of Simple Green, & electrical cleaner (Trichloroethylene) it looks like this: First pic shows all of the parts: Rotor (spinny thing with associated gear and clutch). Stator (housing with red plastic coils inside) housing (mounts to the engine & holds the solenoid lever) End cap (houses the brushes that provide the commutation) Solenoid Lever & associated hardware Dead Spider ..... to keep my grand-kids from messing with it... (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1327385701.1.jpg) Second Pic: This shows the alignment of the solenoid with the rotor actuator lever when it is installed. You see the lever that "actuates" the starter when it is engaged. When I disassembled this area it showed the problem.... the grease covered this whole area and was getting old and "crusty". (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1327385701.2.jpg) Third picture shows where the rotor spins inside the housing with no stator installed yet. (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1327385702.3.jpg) Fourth picture shows the clean housing with nothing installed yet: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1327385702.4.jpg) Fifth picture shows the Stator installed onto the housing so that the rotor can slip in. (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1327385702.5.jpg) So Now the question for the experts: When I took this assembly apart, the lower end ( with the lever and gears) was covered in a nasty old grease that had turned "sticky" and prevented the solenoid from disengaging. I now have perfectly clean parts. Do I re-grease with a Moly- grease and fill the housing cavity & lever area with grease? Or do I go easy with the electrical lubricant shown in the pic? I have to put all the lube in first with the lever before I reassemble, so this is critical to avoid making a huge mess. Stu |
Lo-Fi Version | Time is now: 8th June 2024 - 08:58 PM |
