> stupid question....temp gauge and sender, temp doesn't register...where is sender?
jim912928
post Aug 28 2004, 08:00 PM
Ok, my temperature gauge doesn't register at all. Car runs fine, but I really don't want to run it long without knowing what temperature range I'm running in. So, I need to begin diagnosing this problem but first I'd like to know where in the heck the temp sender is located? I'm guessing it can only be 1) wiring, 2) gauge or 3) sender. So, once I find out where the sender is how do I test it?
Car is a 75 1.8l....again, as usual...thanks in advance!
jim912928   stupid question....temp gauge and sender   Aug 28 2004, 08:00 PM
davep   The temp sensor is located on the bottom of the en...   Aug 28 2004, 08:04 PM
d7n7master   What temp sender are you asking about? Oil or head...   Aug 29 2004, 08:21 AM
jim912928   it's the factory gauge in the center console. ...   Aug 29 2004, 08:29 AM
lapuwali
  Aug 29 2004, 08:32 AM
Brad Roberts   Guy's.. Last time I checked. NO 1.8 engine ha...   Aug 29 2004, 12:05 PM
jim912928   not sure if someone installed a console or not. I...   Aug 29 2004, 12:48 PM
Brad Roberts   All the cars have the wiring for the center consol...   Aug 29 2004, 12:51 PM
jim912928   did a quick check..no rolled up wire under the bat...   Aug 29 2004, 03:06 PM
Brad Roberts   That wire comes out of that main harness under the...   Aug 29 2004, 03:10 PM
jim912928   Ok, I think I found the "taco plate" assuming it i...   Aug 29 2004, 03:37 PM
Brad Roberts   You found it. Now you need to locate the wire comi...   Aug 29 2004, 03:41 PM
Brad Roberts
  Aug 29 2004, 03:44 PM
type47   i combine "1.8" and "temp gauge doesn't work" ...   Aug 29 2004, 03:46 PM
SirAndy   to save money ... oil temp sender was part of the...   Aug 29 2004, 05:28 PM
jim912928   Brad, I went out again and looked at the main wir...   Aug 29 2004, 06:15 PM
- Lo-Fi Version Time is now: 26th July 2026 - 02:53 AM
