DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
After about a month of tuning I have a fueling map that seems close. Most of the map yields air fuel ratios of about 13.8. From what I have read this is about where the motor was designed to run and it runs very well.
However, I continue to have problems with overrun. Between 2600 and 3600 rpms under very light load the air fuel ratio is much richer. This is quite disappointing as I would hope to gain some economy here. The solution would seem to be closed loop with the oxygen sensor leaning out the air fuel mix. The problem is that the pulse widths are so short that O2 correction leads to large changes percentage wise in pulsewidth and fuel mix and the car bucks. I have one more idea to try. I am waiting on some new injectors since it feels as if one cylinder goes dry. If that doesn't help, it appears to be run open loop and send fuel ou the exhaust or run closed loop and suffer some loss of smoothness. I'd appreciate any advice, Dave |
Lo-Fi Version | Time is now: 13th July 2025 - 10:28 AM |
