> Another 3rd Brake Light, Simple to do
mwyatt
post Jan 27 2012, 02:17 PM
I recently installed a third brake light on my '74, for a total cost of around $20. I had a friend with a 914 that got rear ended by a pick up truck at a stop sign a few years ago, so I figured this light was worth adding (my friend was fine, his 914 needed some bodywork). In order to add a thrid brake light you will need to purchase the light itself, and you will need to have a drill and appropriate bits, wire connectors or a soldering iron, extra wire, and simple tools to remove the targa bar trim.
First, buy an LED strip, I bought this one from Pep Boys:
Next remove the three pieces of aluminum trim from the back of your roll bar. I believe I removed the two vertical side pieces first. There is a screw on top and a nut underneath the fender, then they slide off (you may not need to loosen the nut underneath depending on how the trim was reinstalled in the past, it's a lot easier if you leave it loose). The horizontal center piece is held on by three clips, one in the middle and one at each side. The piece will pull off at these three points. Be sure to use gentle pressure because the piece bends and dents easily.
Once removed, measure the horizontal piece and mark the center in pencil. Then find the center of the LED light. Clean the aluminum trim piece and then mount the LED strip to it, matching center to center (the LED strip that I used had an adhesive edge so it was simple to attach to the trim):
Next, drill a hole (or two) in the trim for the wires from the LED strip. The smaller the better here, make the opening just big enough to pull the wires through. Drill slowly to protect the trim. I drilled mine at an angle to make it easier to hide the wires:
Now, thread the wires through the trim piece so that they will not interfere with the clips. Make sure to pull them all to one side, and make it the side that the wires for your tail lights enter into your trunk (left on my car). I had wires coming from opposite ends of the LED I used, so I had to extend the wires on one side and pull them all to the left :
You may now reinstall the horizontal trim piece with the LED. The hardest part is getting the clips to work with the wires running behind them, but it is possible:
Run the ground wire from the LED to a ground wire in your trunk, and run the positive wire to the brake light wire in your trunk. On my '74 the brake light wire is a black wire with green stripes. Do a search if you're not sure which wire to use, there are some great resources on this site to help determine what each wire running to your tail lights is for. I had to add extra wire to the wires that came with the LED to get enough length. You can either solder them together or use wire connectors. Make sure to run the wire down the sail panel where it will be hidden when the trim is reinstalled, then underneath the engine compartment grill on the left and into the trunk. I used a special type of connector to tap into the ground wire and brake light wire (I forget the name of the connector, see pics):
Reinstall the vertical side trim on the roll bar and you are done!
Off:
(it is almost hidden in daylight when off)
On:
Good luck with your own install!
Tom_T
post Jan 27 2012, 02:56 PM
TMI....
...or you can go buy this for a bit more with all of the connections set up for brake & emergency flashers....
http://www.ebay.com/itm/914-Multifunction-...=item256b01c044
No affiliation, don't know the vendor & I haven't used it - but looked like pretty good idea/product when I saw it on eBay earlier!
effutuo101
post Jan 27 2012, 02:58 PM
Nice work! That looks good.
post Jan 27 2012, 03:18 PM
Resident German
(IMG:style_emoticons/default/thumb3d.gif)
Tom
post Jan 27 2012, 08:55 PM
That is a great modification and I hope it will keep folks from rear-ending you, and everything we can do to prevent that is good. Good job, and I hope it keeps you safe, thanks for posting this. (IMG:style_emoticons/default/smile.gif)
Tom
bigkensteele
post Jan 27 2012, 09:43 PM
Major Member
I like it too. The last pic makes me think that it is pretty effective, right there in the line of sight of most cars/drivers. I would rather have that than the one that Tom posted, which isn't much higher than the brake lights.
Dr Evil
post Jan 28 2012, 11:37 AM
Send me your transmission!
QUOTE(mwyatt @ Jan 27 2012, 03:17 PM) *
Off:
On:
Excellent job. I might just copy this in the future. The location of it is perfect for SUV view, and it does not block up any of the rear window (IMG:style_emoticons/default/thumb3d.gif)
mwyatt
post Jan 28 2012, 12:51 PM
Thanks for the feedback guys! I hope I helped someone out.
Jacob
post Jan 28 2012, 07:44 PM
Nice work That looks great! I agree that it is great that it does not interfere with the rear window. Thanks for posting that!
913B
post Jan 29 2012, 12:39 AM
Thats pretty cool, good job ! How visible is it in the daytime ?
TC 914-8
post Jan 29 2012, 12:59 AM
I like it, nice job and in the final picture it looks very effective.
Is the LED strip mounted on the bottom of the trim piece? it's hard to tell but I cannot see it from the back (IMG:style_emoticons/default/confused24.gif)
EdwardBlume
post Jan 29 2012, 02:47 AM
Classic thread? (IMG:style_emoticons/default/beerchug.gif)
post Jan 29 2012, 02:34 PM
Nice job. Someone else here did the same thing awhile back.
TC 914-8
post Feb 18 2012, 12:40 AM
I looked at my local AP store and they wanted $40 bucks for a 20" section of red LED strips. I found a 10' roll on Ebay for $12 bucks, came on the slow boat from China, not kidding. So anyway I followed the pics on the beginning of the thread and in less than an hour I had mine installed. Here is a picture with them powered up, I still have to wire them into the brake light circuit, but very simple and stealth solution to adding protection from Grama not paying attention, the kids behind me texting while driving.
Thanks mwyatt for the idea, I have more of the red LED strip available if any local folks want a piece.
I'll put a better pict up tomorrow
MecGen
post Feb 18 2012, 08:23 AM
8 Easy Steps
QUOTE(TC 914-8 @ Feb 18 2012, 01:40 AM) *
Nice (IMG:style_emoticons/default/beerchug.gif)
Good to see this, nothing more scary then stopping for a light then watching someone come up way too fast in the rear view mirror (IMG:style_emoticons/default/hissyfit.gif)
Regards
913B
post Feb 18 2012, 12:42 PM
Were those the self adhesive type, how wide was the strip, is it bright enought in the daytime ?
Harpo
post Feb 18 2012, 02:41 PM
Could you please post the link to the ebay site where you got your LEDs?
Thanks
David
Drums66
post Feb 18 2012, 03:04 PM
914 Rudiments
.....Maybe more attention to the rear (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/shades.gif)(GET OFF THE PHONE!!!)
mwyatt
post Feb 18 2012, 03:25 PM
TC 914-8, nice job! Cool car too.
abnrdo
post Feb 18 2012, 04:24 PM
Nice! I have to do something like that to mine!
- Lo-Fi Version Time is now: 9th June 2026 - 07:43 AM
