To glue or not to glue..., Oil pump gasket glue or not? |
larss |
Jan 29 2012, 12:02 AM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Im on my way putting a 1,7 engine together using Curil K2 on the case halves.
Should I glue the gasket behind the oil pump also on one or both sides? (when taking it apart it looked to be glued on both sides) Also I can not get Loctite 565 where I live is there an alternative for the galley plugs etc? Lars S |
nathansnathan |
Jan 29 2012, 08:42 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I've found permatex 3h or aviation gasket maker to work better on case halves. Curil k2 is too thin which makes it good for where the smallest bit of space is critical, like an oil pump cover. Do both sides for sure. Loctite 518 might even be better for galley plugs as it dries without air.
larss |
Jan 29 2012, 02:10 PM
Lo-Fi Version | Time is now: 13th May 2024 - 08:35 PM |
