first run on my new setup, awesome |
Woody |
Jan 29 2012, 08:09 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Well after doing most of the mods I had planned for this winter I came in 4th in class and 9th overall out of 135 cars at our first autocross this year. In my class I finished behind Beth McClure-Strelneiks in her slightly insane Mazda in 3rd, then Frederico DelToro in his Boxster in second, and then Troy Acosta co-driving the Mazda. I am stoked considering the company I was in. I still have some understeer to dial out and it may be time for a rear bar.
https://www.youtube.com/watch?v=9t6MiW34I14...be_gdata_player |
ottox914 |
Jan 29 2012, 08:25 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Looks like fun... tell us more about the car- motor, tires, suspension. More pics never hurt either.
Woody |
Jan 29 2012, 09:00 PM
Well its a 75 with a cammy 2056 with 44 Empi carbs. 21mm torsion bars, 180 rear springs, 19mm front bar, 5 lug conversion using T struts, drilled rear hubs, hard plastic bushings throughout, camber plates up front, 205/225 hankook z214 soft compound tires and some other small things. I'm stoked with how it ran. (IMG:http://www.914world.com/bbs2/uploads_offsite/i288.photobucket.com-12530-1327892399.1.jpg)
J P Stein |
Jan 29 2012, 09:41 PM
You didn't say how stiff/soft your front AR bar is set, but.....
I wouldn't use a rear AR bar unless you have an LSD.....lifting the inside rear tire will ruin your AX day. Jack up the rear spring rate to induce oversteer. .....bout 250s ought to do it. If that is too much one tightens the front bar to take some out. I don't think much of those tires but you may as well run em' till they chord. |
Woody |
Jan 30 2012, 07:33 AM
Thanks JP. I was kinda thinking the same thing. The front bar is about 1 3/4 from full soft but I need to get shorter drop links cause the angles are all wrong. Hoosiers were out of my budget so I opted for the hankooks. They didn't feel too bad honestly. I guess we'll see how they do when I get the suspension sorted.
Jon. |
ottox914 |
Jan 30 2012, 07:59 AM
Looks like a nice, clean car. What are those rims? And I'm curious about the camber plates- are those the "standard" aftermarket strut top mount that mirrors the design of the factory piece, or are they more like the ones Chris Foley sells that weld in and change the top of the fender under the hood?
New sticky tires are yummy. |
Woody |
Jan 30 2012, 09:08 AM
The rims are old BBS 15x7 and 8. They weigh a ton. I have the weltmeister camber plates which I'm kinda kicking myself over. I shoulda bought the tarrett ones. Haven't had any problems yet but the tarrett ones appear much sturdier.
Woody |
Jan 30 2012, 09:23 AM
Any preference to progressive rate rear springs versus non progressive? The 180 pounders I put on are progressive.
J P Stein |
Jan 30 2012, 10:18 AM
Non-progressive.....unless you like variable handling (IMG:style_emoticons/default/biggrin.gif) .
It sounds as though you're using stock diameter springs. 200in/lb springs are the max available (from Renegade) and are expensive....200 bucks when I bought some years ago. 2.5 inch diameter (using threaded collars) were cheeper (50 bucks each) and come in 25lb increments up to 600 in/lbs. They also make ride height & corner ballancing adjustments a snap....+ they are lighter. Attached image(s) |
yeahmag |
Jan 30 2012, 06:27 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
What cam/heads/exhaust are you running? Sounds good!
Woody |
Jan 30 2012, 07:32 PM
Jan 30 2012, 07:39 PM
Resident German Group: Admin Posts: 41,616 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That rear end looks waaaaay too high!
Did you remove the engine for that pic? (IMG:style_emoticons/default/biggrin.gif) |
yeahmag |
Jan 30 2012, 07:46 PM
That's my build! 2056, 86A, 2L heads, and a "kustom" 4-1 header with a Phase 9 style muffler from Racer Chris.
How much compression are you running? |
Randal |
Jan 30 2012, 09:43 PM
Well after doing most of the mods I had planned for this winter I came in 4th in class and 9th overall out of 135 cars at our first autocross this year. In my class I finished behind Beth McClure-Strelneiks in her slightly insane Mazda in 3rd, then Frederico DelToro in his Boxster in second, and then Troy Acosta co-driving the Mazda. I am stoked considering the company I was in. I still have some understeer to dial out and it may be time for a rear bar. https://www.youtube.com/watch?v=9t6MiW34I14...be_gdata_player Congratulations on a good showing. 9th out of 135 cars is rocking. (IMG:style_emoticons/default/flag.gif) Did you have a chance to corrner balance the car before the event? I also agree with Andy that your car looks high, but maybe you're running it on the street as well. Here is a picture of my car when I was still running 205's for comparison. |
Woody |
Jan 30 2012, 10:44 PM
Yes the car is high in the back. I intended to buy bilsteins but my budget ran out. They'll be on soon enough. If I recall correctly I believe my compression ended up in the 8.5-1 range but I built this motor 5 years ago so I may be wrong.
Woody |
Jan 30 2012, 10:46 PM
Oh and yes I balanced it.
Randal |
Jan 31 2012, 11:49 AM
Oh and yes I balanced it. Yup, get the height right then corner balance that puppy. I actually think CBing is one of the most important suspension things you can do. (IMG:style_emoticons/default/biggrin.gif) |
Woody |
Jan 31 2012, 02:09 PM
This is without me in the car. Swaybar disconnected. Car needs to go on a diet. Those delrin suspension bushings are nice. (IMG:http://www.914world.com/bbs2/uploads_offsite/i288.photobucket.com-12530-1328040567.1.jpg)(IMG:http://www.914world.com/bbs2/uploads_offsite/i288.photobucket.com-12530-1328040568.2.jpg)
campbellcj |
Jan 31 2012, 10:45 PM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Nice looking car! I broke the Weltmeister camber plates, but heard they may have improved the design and/or materials later. I'd keep 'em unless they break - save your money for tires and seat time.
I have the weltmeister camber plates which I'm kinda kicking myself over. I shoulda bought the tarrett ones. Haven't had any problems yet but the tarrett ones appear much sturdier. |
Randal |
This is without me in the car. Swaybar disconnected. Car needs to go on a diet. Those delrin suspension bushings are nice. (IMG:http://www.914world.com/bbs2/uploads_offsite/i288.photobucket.com-12530-1328040567.1.jpg)(IMG:http://www.914world.com/bbs2/uploads_offsite/i288.photobucket.com-12530-1328040568.2.jpg) Yea, I looked at those numbers and thought you had it perfect, until I re-read the post and realized that was without you in the car. Looks like you need some weight in the drivers seat so that you can dial in the right balance, as if you were out there running. Do that and I'll bet you feel a difference. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 01:42 PM |
