Installing new front trunk seal, Old one came out nice and clean |
qa1142 |
Aug 31 2004, 09:21 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
What do I use to get the same nice seal and be able to remove the new seal when i have the car painted?
mightyohm |
Aug 31 2004, 09:56 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Buy a new seal, try to get a quality OEM replacement, some of the cheap ones are bad and fall apart at the seams. Use 3M black weatherstrip adhesive to attach JUST the corners of the seal, just a dab at each corner is usually enough. This will allow you to yank the seal when you need to without damaging it if you are careful.
tod914 |
Aug 31 2004, 10:22 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Dont glue it in after you have the car done. You want to be able to pull it out each time you wash it, so you can dry the channel.
mightyohm |
Aug 31 2004, 10:31 AM
Mine won't stay unless i glue the corners in. I had to glue them one at a time and stretch the seal into place for the next.
GaroldShaffer |
Aug 31 2004, 10:41 AM
You bought another 914? Group: Benefactors Posts: 7,622 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
QUOTE Dont glue it in after you have the car done. You want to be able to pull it out each time you wash it, so you can dry the channel. Is the concern here that the water will collect in the corners by the headlight buckets? When I get MY car painted I plan to cut a notch in the channel by the corner so the water will drain in behind the headlight and out the drain hole. Same for the bottom channel between the headlights, notch the corners so it will drain behind the bumper. Bad idea? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 02:07 AM |
