Timing Questions - help me understand, 009 Distributer, Weber Carbs |
thomasotten |
Aug 31 2004, 06:07 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I need some help understanding how to time my engine.
I was looking over my fan, and the only mark I can see on it, other than grease, is the notch that appears when the engine is at TDC. How many painted marks do I need to time this engine properly? And at what degree/direction should they be? I understand this needs to be done at a certain engine speed as well. If anyone knows what the proper speed/timing settings are, please advise. This is a 009 distributer, if that makes a difference. All the literature I have found seems to be based on the vacuum advance distributer. The engine is running on the ground, and, if possible I would like to time it before installing, but is that impossible without a tach? |
Mueller |
Aug 31 2004, 06:19 PM
if you have an adjustible timing light (which everyone should have (IMG:style_emoticons/default/smile.gif) ),
you only need the one TDC mark..... the timing should be something like 27° @ 3000 or 3500 rpm each motor is a little different, but that'll be a safe number until you get it running and can put a load on it so see if it likes or dislikes more advance *for a few bucks more, you can get a digital timing light that'll read the RPMs and is adjustible...once you use one of these a few times, it'll pay for itself (IMG:style_emoticons/default/smile.gif) |
sanman |
Aug 31 2004, 07:41 PM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
get an engine analyzer most of the read rpm from a simple conection
i got one at a swap meet for $5 (IMG:style_emoticons/default/smilie_pokal.gif) |
cgnj |
Aug 31 2004, 07:47 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
All the fans that I have touched have the red 27 BTDC degree mark. Out of the 4 fans on my shelf, only one has the a stamping with a zero on it. You should only need the 27 mark to time it with the 009. I threw my 009 away. Better off running any stock distributor without hoses. The fan turns from passenger side to drivers side. You should see the red mark and about 4 or five fan blades then you are at TDC. Carlos |
Lo-Fi Version | Time is now: 6th May 2024 - 09:11 AM |
