coil mounting location, any caveats? |
machina |
Sep 1 2004, 10:34 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
wanted to mount my bosch coil on the other side of metal bulhead in the rear trunk.
is it a problem running the coil lead thru a metal bulkhead with regard to arcing etc? the other location I had in mind is about 12" away from the CD box. Is that a bad choice as well. My intention is to mount as many components out of the engine bay for easy access and motor removal. thanks, dr |
ArtechnikA |
Sep 1 2004, 10:42 AM
QUOTE(synthesisdv @ Sep 1 2004, 08:34 AM) wanted to mount my bosch coil on the other side of metal bulhead in the rear trunk. is it a problem running the coil lead thru a metal bulkhead with regard to arcing etc? run a nice grommet and you'll be fine; i've seen this on many race cars. check with your safety/tech guys regarding holes in the firewall tho... |
HarveyH |
Sep 1 2004, 11:11 AM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
For a real Whoop-de-doo, MSD makes this, and other ignition system manufacturers probably make something similar
Harvey Attached image(s) |
URY914 |
Sep 1 2004, 11:53 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,693 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I have one of those MSD thru-wall things on my car.
Works well. Paul |
URY914 |
Sep 1 2004, 11:59 AM
Also be sure to mount the coil very secure. I have mine come loose once and it srcews everything up real quick.
Paul |
Lo-Fi Version | Time is now: 19th May 2024 - 06:24 AM |
