PATRICK MOTORPORTS 914FWSB SHIFT ROD BEARING, Who's using these?, Easy to install? |
euro911 |
Feb 5 2012, 10:11 PM
As some of you may know, my '75 (aka The 'BB') was butchered by a previous owner. The car had a tail-shift transaxle in when I acquired it (IMG:style_emoticons/default/mad.gif)
Even though we converted the car back to the correct side-shift transaxle, there is a shift-rod pivot assembly from an early [tail-shift] car riveted to the firewall. To make matters worse, it isn't even square (not installed quite 90 degrees to the firewall). I was able to bend it somewhat and its straighter than it was, but I still can't install an OEM side-shift type of rubber shift-joint cover on it (IMG:style_emoticons/default/dry.gif) Since the drive train is still out, I'm thinking of drilling out the rivets, removing the incorrect shift-rod pivot assembly and installing a PMP shift rod bearing. 1. It looks like the PMP bearing will accept the OEM side-shift shift-joint cover, but PMP's ad doesn't mention anything about it, ... so I thought to ask here, if that is true? 2. How is this bearing installed? (it appears to bolt in) (IMG:style_emoticons/default/confused24.gif) 3. Do you guys shave the OEM shfit rod down to the correct OD to fit the bearing's ID, or just purchase one of PMP's special shift rods? (PART#PMP914RSR) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:54 AM |
