| Bleyseng |
May 2 2003, 07:32 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Here is a pic of the part I have that is supposed to be a intermitant relay.
Geoff (ok Brad, I know I should PM him but how do you post or attach a pic to a pm?) Attached image(s)
| Brad Roberts |
May 2 2003, 07:54 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Post all you want... You cant attach a pic to a PM. You have to provide the URL from a webs server with the IMG tags on it....
B |
| SirAndy |
May 3 2003, 01:16 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Bleyseng @ May 2 2003, 06:32 PM) Here is a pic of the part I have that is supposed to be a intermitant relay. geoff, does it have 5 pins? 4 in a circle, one in the middle? if so, it's the one (IMG:style_emoticons/default/wink.gif) the serial# is correct, quote from the AA catalog: "33, relay for wiper control 1973-76, 477 955 531 a, In Stock" Andy |
| Bleyseng |
May 3 2003, 02:21 PM
Yup, it has five pins.
Geoff |
| SirAndy |
May 3 2003, 06:28 PM
QUOTE(Bleyseng @ May 3 2003, 01:21 PM) Yup, it has five pins. Geoff alright then, please send it down to SSI. and let me know how much $$$ and where to send it (IMG:style_emoticons/default/wink.gif) thank you sir, Andy |
| SirAndy |
May 19 2003, 06:51 PM
here's a pic of the relay-connector mounted.
the relay is not yet added. wiring was straight forward, there's actually a whole page in the haynes manual about the wiring for this relay. one cable comes straight from your steering column (73 and newer) and goes to the relay, the other cables come from/go to the wiper motor. i can whip up some more details if interested. Andy (IMG:http://www.sirandy.com/pix/914/2003.05.19/IMGP2073.JPG) |
| Jeff Krieger |
May 19 2003, 08:17 PM
Unregistered |
QUOTE(SirAndy @ May 19 2003, 05:51 PM) here's a pic of the relay-connector mounted. the relay is not yet added. wiring was straight forward, there's actually a whole page in the haynes manual about the wiring for this relay. one cable comes straight from your steering column (73 and newer) and goes to the relay, the other cables come from/go to the wiper motor. i can whip up some more details if interested. Andy Yes please. I would like to add an intermittent relay to my '73 2.0 in the future and I could use the information. |
| ThinAir |
May 19 2003, 09:19 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,575 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
Andy -
Is that mounted on the passenger side or the driver side? What page in the Haynes book are you referring to? I can't seem to find it. |
| Bleyseng |
May 19 2003, 10:05 PM
Drivers side, page 165 left side, Flick wipe system
| ThinAir |
May 19 2003, 10:09 PM
Now if I only knew how to read a current flow diagram. Seriously... I've never been able to translate between "current flow" and the actual wiring in a car. Can anyone explain this in plain english?
| SirAndy |
May 19 2003, 10:14 PM
QUOTE(ErnieDV @ May 19 2003, 09:09 PM) Can anyone explain this in plain english? i'll write something up. it's easier if you have a color diagram (IMG:style_emoticons/default/rolleyes.gif) Andy |
| markb |
May 20 2003, 10:30 AM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Hi Andy, yes please do. I pulled the relay & wiring from one of my parts cars, but the wiper & wires had been removed. I'm gonna try & wire it into an early 70 (with the turn switch on the dash) so any help would be appreciated.
| SirAndy |
May 20 2003, 10:34 AM
QUOTE(markb @ May 20 2003, 09:30 AM) Hi Andy, yes please do. i started a new thread, which you can find here: Wiper Relay Instructions Andy |
Lo-Fi Version | Time is now: 19th June 2026 - 10:21 PM |
