914-6 transmission rebuild, Can I reuse the 1st gear |
914Gelb |
Feb 8 2012, 03:06 AM
Member Group: Members Posts: 90 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello guys,
I've bought my car without any test drive because it was unsed many years. Now my transmission is on my todo list. I already opened the case to inspect the 1st gear. I saw a syncro ring which seems to be less used but the dog teeth and the slider speeks other words. My impression.. I have to change slider, dog teeth and syncro. I added some pictures, who can distinguish between poo parts and reusable ones. Attached thumbnail(s) |
Dr Evil |
May 15 2012, 06:50 AM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
That is toast. The race in the case should not move.
I have good used ring and pinion. If you can not get someone local to you to adjust the ring and pinion, you can use the method that other makers use in that they apply dye to the ring and check where the pinion contacts and adjust from there. I had a guy in New Zealand use this method as he did not have access to the tools or a shop with them. His results were fine, but you may have to do it a few times, I dont know. I always use the tools. |
Lo-Fi Version | Time is now: 6th May 2024 - 02:07 PM |
