914-6 transmission rebuild, Can I reuse the 1st gear |
914Gelb |
Feb 8 2012, 03:06 AM
Member Group: Members Posts: 90 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello guys,
I've bought my car without any test drive because it was unsed many years. Now my transmission is on my todo list. I already opened the case to inspect the 1st gear. I saw a syncro ring which seems to be less used but the dog teeth and the slider speeks other words. My impression.. I have to change slider, dog teeth and syncro. I added some pictures, who can distinguish between poo parts and reusable ones. Attached thumbnail(s) |
914Gelb |
May 15 2012, 11:35 PM
Thanks for the answers! I also think it makes sence to use an other case but my transmission is a genuine 914-6. As far as I know some gears are different to the 914-4. If I use an other case I have to move this gears. At the end the clearances are again wrong and measurement is necessary.. or??
If the outer race moves and and I use locite than I hope it will be very difficult to remove. That's at the end the goal a stable outer race which never losse under normal operation. If I like to remove them later I can also use than an other case. I'm going to ask loctite, maybe they also have solutions for that case which also includes the workflow how it can removed afterwards. I have no fear for the measurments, I like the work and have the time. There ist the option to make a fault but I will learn a lot! If its not posible to get the tools I'm going to make it by my own. Lathe and milling is possible. If this is necesarry I will post my tools. |
Lo-Fi Version | Time is now: 6th May 2024 - 07:36 PM |
