914-6 transmission rebuild, Can I reuse the 1st gear |
914Gelb |
Feb 8 2012, 03:06 AM
Member Group: Members Posts: 90 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello guys,
I've bought my car without any test drive because it was unsed many years. Now my transmission is on my todo list. I already opened the case to inspect the 1st gear. I saw a syncro ring which seems to be less used but the dog teeth and the slider speeks other words. My impression.. I have to change slider, dog teeth and syncro. I added some pictures, who can distinguish between poo parts and reusable ones. Attached thumbnail(s) |
914Gelb |
May 27 2012, 01:50 PM
I continued my work with cleaning some parts of the transmission. Blasting oft parts which are later will be zink plated and case parst
I use WD40 to stop corusion of the magnesium case. If all is done and the case is closed after the rebuild I will use wax for that. If I have the nissing Parts I will teardown the two shafts. I like to replace all syncros with new ones. Georg |
Lo-Fi Version | Time is now: 6th May 2024 - 11:21 AM |
