carburetor fuel pump wiring |
rgolia |
Feb 13 2012, 12:21 PM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
Need advice on how to wire fuel pump for webers, it is currently wired to the coil.
ClayPerrine |
Feb 13 2012, 12:37 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Wiring the fuel pump is a half assed way to do it. It is also very bad for the engine. It lowers the available voltage to the coil, and weakens the spark.
I would suggest that you wire it to the fuse block, to the fused side of fuse #8 (IIRC). It will switch on when the key is on, and won't pull load from the coil. |
clapeza |
Feb 13 2012, 01:14 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Lo-Fi Version | Time is now: 17th May 2024 - 06:12 PM |
