| machina |
Sep 11 2004, 03:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
There are a pair of coolers, these brackets were 4 hour to fab, about 3.5 hours longer than I planned. Gotta do the second set sunday.
Planning on mounting coolers out back. If they work out I'll let you know. dr Attached thumbnail(s)
| echocanyons |
Sep 11 2004, 04:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,112 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
Looks good are you mounting it under the trunk?
| lagunero |
Sep 11 2004, 04:10 PM
Donkey Member ![]() ![]() ![]() Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
Very nice! Out back...where?
| MXMARK |
Sep 11 2004, 04:13 PM
Member ![]() ![]() Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
Looks great, good luck. Mark
| machina |
Sep 11 2004, 04:19 PM
QUOTE(lagunero @ Sep 11 2004, 06:10 PM) Very nice! Out back...where? In the are where the stock muffler is located. Removed the old brackets. Don't plan on running at idle more than 1 minute, on the grid or in the pits. I think there will be quite a bit of airflow back there between 80 => 130 mph. I am prepared to move them or duct them if there is not enough cooling capacity. Won't know till she runs at speed. dr Attached image(s)
| Jeroen |
Sep 11 2004, 04:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Hard to see in the pic, but are you using any rubber insulators between the mounts and the cooler?
Pieces look very nice (just like the rest of you car) |
| machina |
Sep 12 2004, 06:15 AM
QUOTE(Jeroen @ Sep 11 2004, 06:37 PM) Hard to see in the pic, but are you using any rubber insulators between the mounts and the cooler Yes, rubber spacers at each of the 8 mounting points. They are not in the picture, waiting on proper hardware from the UPS man. dr |
Lo-Fi Version | Time is now: 15th January 2026 - 12:17 PM |
