Brake pedal assy wiring, I have a loose wire coming off it |
matthepcat |
Mar 1 2012, 03:28 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Hey world,
I searched for a while to no answer. I have a 75' car, and am trying to find out what all the wires coming off the brake light switch on the pedal assembly are. Only reason I ask is there is a red wire with white stripes coming out of that connector unconnected. On the 74' wiring diagram it looks like it went to a Voltmeter?? Thanks! (IMG:style_emoticons/default/smile.gif) Matt |
type47 |
Mar 1 2012, 04:01 PM
http://www.pelicanparts.com/914/parts/Elec...lectric_74D.jpg
track 51 does show a red/white from the brake light switch to the voltmeter in the console. Do you have a console with a Voltmeter? You can also see from the diagram that red/white supplies power to several gauges, lights, stuff ... |
jim_hoyland |
Mar 1 2012, 04:04 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
http://www.pelicanparts.com/914/parts/Elec...lectric_74D.jpg track 51 does show a red/white from the brake light switch to the voltmeter I think that was the way the '75 voltmeter was wired. I remember the gauge deflecting every time I hit the brakes, then wired it directly to the fuse panel... (IMG:style_emoticons/default/smile.gif) |
matthepcat |
Mar 1 2012, 06:33 PM
My car may have come with that stuff.
I actually am installing new gauges, so maybe this could be a good source of switched 12v. My conversion has a giant alternator, so I have no brake light flicker. Thanks for your input guys. Matt |
Lo-Fi Version | Time is now: 18th May 2024 - 01:30 AM |
