The moment of truth, 74 2.0 Djet |
914itis |
Mar 4 2012, 05:15 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
here we are.
Put everything together, and engine refuses to start, I noticed that there is no power to fuel pump when cranking. I jumped the fuel pump and it still does not start, but if i squirt some starting fluid and crank, It starts, meaning that there is spark. I know about the seat belt relay, I connected together the 2 thick yellow wires. I don't know what else to do, other than post and wait for the experts. |
JeffBowlsby |
Mar 4 2012, 05:59 PM
914 Wiring Harnesses Group: Members Posts: 8,520 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Try going through these guides:
http://bowlsby.net/914/Classic/zTN_Man06.pdf http://bowlsby.net/914/Classic/zTN_Man04.pdf |
rgalla9146 |
Mar 4 2012, 06:20 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
here we are. Put everything together, and engine refuses to start, I noticed that there is no power to fuel pump when cranking. I jumped the fuel pump and it still does not start, but if i squirt some starting fluid and crank, It starts, meaning that there is spark. I know about the seat belt relay, I connected together the 2 thick yellow wires. I don't know what else to do, other than post and wait for the experts. Hey Paul get a jumper wire to extend from some power source to the socket under the fuel pump relay that turns the pump on. at least you can hear it run. we'll talk soon R |
914itis |
Mar 4 2012, 10:19 PM
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) I am happy to report on my 914th post that the engine started. after replacing the fuel pump relay twice. Thanks all now I just have to fine tune and check for leaks.
jonferns |
Mar 4 2012, 11:00 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
Elliot Cannon |
Mar 4 2012, 11:16 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
In my case it wasn't the fuel pump relay that was bad but corrosion in the relay socket.
914itis |
Mar 4 2012, 11:19 PM
I know it was not, because I had some spare relay boards with the same result.
76-914 |
Mar 5 2012, 11:05 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/thumb3d.gif) Good job Paul (and son). (IMG:style_emoticons/default/smilie_pokal.gif) Now for phase 2; running down the gremlins.
chuckc |
Mar 5 2012, 11:43 AM
Member Group: Members Posts: 196 Joined: 30-August 10 From: Astoria NY Member No.: 12,123 Region Association: North East States |
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) I am happy to report on my 914th post that the engine started. after replacing the fuel pump relay twice. Thanks all now I just have to fine tune and check for leaks. Congratulations! |
914itis |
Mar 5 2012, 11:17 PM
(IMG:style_emoticons/default/thumb3d.gif) Good job Paul (and son). (IMG:style_emoticons/default/smilie_pokal.gif) Now for phase 2; running down the gremlins. Thanks, |
914itis |
Mar 5 2012, 11:21 PM
I mounted the Muffler today and the engine sounds great, with a minor leak on one of the valve covers ( no big deal ) ordering valve cover gasket, will do valvle ajustment and set the timing as soon as I receive them.
jonferns |
Mar 6 2012, 08:00 AM
Flip your engine shelf fuel lines (IMG:style_emoticons/default/shades.gif)
Looks great! Can't believe the progress you've made since you bought the car from me, what was it, just a year ago? |
914itis |
Mar 6 2012, 08:44 AM
I have to, and thanks . Almoat there .
Lo-Fi Version | Time is now: 28th May 2024 - 10:51 AM |
