914ghost |
BOB ![]() ![]() Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 ![]() |
So, I gets a set of 320i brake calipers off a wrecked car the other day.
Very good clean condition, pads are like new. They were FREE, so what the heck right? I got a 70' so ..they bolt right on -- RIGHT? Not quite, but pretty slick. Bend the brake line, I had to grind on the outside of the actual caliper body just a smidge (through the part# stamping) because my wheels hit'm - 2 liter fuchs, totally stock. Not sure about that - anyways, Okay, bolt'em on, bleeed, bleed, bleed...adjusted the proportoning (big word) valve rod all the way in...tried IN and OUT not much diff. Pedal is still a bit soft, but works. Summary is: No Big deal, maybe I need the big Master cylinder? They work about as good as before. Pad area is like 40% larger, but it's not much of a difference- did I forget something? -Bob O |
Lo-Fi Version | Time is now: 13th July 2025 - 10:15 AM |
