Possibly got robbed, update 3/13/12 IT IS FINISHED !!! |
Mark Henry |
Mar 6 2012, 02:22 PM
Yeah, it looks bad. Stevie Wonder can see that it's hosed up. The benefit of doubt I extended for the machine shop only goes so far. Agreed, that doesn't even pass visual inspection. Why would someone work on that? (IMG:style_emoticons/default/blink.gif) |
stugray |
Mar 6 2012, 02:34 PM
"Will you please come and look at my damage with me sir?
If we look together maybe some magic will happen. This is horri- feel this! This even feels damaged! Do you have tools, can you fix this right now? This is horribly- this feels so horribly damaged. Even if I was blind I would know this is horribly damaged, by the way it feels." http://www.youtube.com/watch?v=58j_ZbpiCjM Stu |
gothspeed |
Mar 6 2012, 04:08 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I have seen crank journals weld repaired, remachined then nitrided for not too much money ........ could not the same process be used on that end?
carr914 |
Mar 6 2012, 06:13 PM
Racer from Birth Group: Members Posts: 118,774 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Why, just start again with a better one & a different machinest (IMG:style_emoticons/default/smash.gif)
Mar 6 2012, 07:25 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Looks like it sat in the water and got rusty...then sandblasted.
rich |
VaccaRabite |
Mar 6 2012, 08:14 PM
En Garde! Group: Admin Posts: 13,446 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Joe, is there corresponding damage on the flywheel where it connects, or did you get a new flywheel?
I don't understand how this damage could have happened and the flywheel still ran true. Zach |
jsayre914 |
Mar 6 2012, 08:28 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Joe, is there corresponding damage on the flywheel where it connects, or did you get a new flywheel? I don't understand how this damage could have happened and the flywheel still ran true. Zach Tony said the flywheel was fine, it is the original one resurfaced. I drove this car every day for more than 2 years with this crank. (IMG:style_emoticons/default/confused24.gif) Your guess is as good as mine (IMG:style_emoticons/default/WTF.gif) |
infraredcalvin |
Mar 6 2012, 09:45 PM
Distracted Member Group: Members Posts: 1,520 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I used to take pics of all angles and scribe a mark in a hidden spot to be sure I got my part back. Once had a shop call me about the "hidden" mark and if I wanted buffed out... At least he examined the part well enough to find my mark...
aircooledtechguy |
Mar 6 2012, 11:08 PM
Looks like it sat in the water and got rusty...then sandblasted. rich (IMG:style_emoticons/default/agree.gif) It doesn't look like tool marks. It looks like pitting over a long time. Just a wild guess: I would bet this is NOT the crank you dropped off, but possibly is the flywheel you dropped off. Maybe is was switched (intentionally or UN-intentionally) with another customers POS crank core. I would recommend approaching this as if an honest mistake was made and allow them to make it right. I can tell you from experience that your attitude will make a big difference on how you are treated in the end. All people are capable of making a mistake, it's how they take care of that mistake that separates the good vendor from the bad. This could be just a simple error (grabbing the wrong crank). Give the guy the opportunity to make it right before accusing him of screwing you. That aught to be a fun one to set end-play on. . . (IMG:style_emoticons/default/av-943.gif) |
firstknight13 |
Mar 7 2012, 01:53 AM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
firstknight13 |
Mar 7 2012, 01:55 AM
Joe, is there corresponding damage on the flywheel where it connects, or did you get a new flywheel? I don't understand how this damage could have happened and the flywheel still ran true. Zach they were both equally rotted and so it took away an equal amount.... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/sheeplove.gif) |
Woody |
Mar 7 2012, 07:54 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
It doesn't look like rust to me. It looks like galling, most likely from loose or missing flywheel bolts. Maybe at one point in that engines life the bolts backed out and the flywheel spun on the crank and then the bolts were just put back in. Just a theory.
gothspeed |
Mar 7 2012, 09:25 AM
Why, just start again with a better one & a different machinest (IMG:style_emoticons/default/smash.gif) ......... my guess it would be less expensive to fix than to buy another crank and have everything redone. The fix can be just as good and possibly even more reliable as one would have a fresh surface. but it was just an idea and not intended for people that have a lot extra money (IMG:style_emoticons/default/shades.gif) Also as aircooledguy mentioned, the crank may not even be the same one that was dropped off. unless it was tagged/marked as soon as it was delivered, it could have been grabbed by mistake or?? |
jsayre914 |
Mar 7 2012, 02:59 PM
jsayre914 |
Mar 7 2012, 05:14 PM
Machine guy called,
basically said that he did what I asked him to do, and he would make it right but I have to wait until next week because he is swampped. (IMG:style_emoticons/default/sad.gif) And He goes on to say that the flywheel must be pretty messed up also. (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/wacko.gif) I dont have the flywheel because its sitting in tonys shop. WTF WTF WTF now I will call Tony tommorow and ask him to inspect the flywheel closer. On the other hand Tony has a pretty good idea of engine building, I can only assume he checked the flywheel good after seeing the condition of my crank. Im gonna step outide (IMG:style_emoticons/default/help.gif) |
rick 918-S |
Mar 8 2012, 10:13 AM
Hey nice rack! -Celette Group: Members Posts: 20,464 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
You couldn't pay me to run that crank. I would get another one and start with a fresh feeling of confidence. Nothing worse than doubting whether or not the work or part will last the life of the engine.
Mar 8 2012, 11:22 AM
But Rick, the crank always lasts the life of the engine. Because when the crank goes, the engine is gone. (IMG:style_emoticons/default/wink.gif)
(Yes, I agree with the "use a different crank" people.) --DD |
Mark Henry |
Mar 8 2012, 01:30 PM
If he has to replace the crank how is that going to be now considered a balanced assembly?
I'd say the crank is your responsibility to replace it, but the machinist should never have balanced it in that condition and demanded a better crank right from the start. If the crank is replaced than the whole assembly fan, crank, fly and PP will need to be rebalanced. A proper balance is each part balanced separately and then the rotating assembly is bolted together and balanced again. The bolts/washers will be needed for this part of the job. (BTW I balance the fly and PP bolts/washers so that the order is not important.) I'd be asking if this was done. |
jsayre914 |
Mar 12 2012, 09:21 AM
Machine guy called.....
The crank is ready. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) I will be picking it up tommorow. Pics will also be tommorow (IMG:style_emoticons/default/smile.gif) Now that the crank has been repaired... should I have everything balanced again? I did thank him very much for workin things out with me. It pays to be polite (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/shades.gif) |
Mark Henry |
Mar 12 2012, 09:36 AM
Please post pics of the repaired crank.
Lo-Fi Version | Time is now: 23rd May 2024 - 02:02 PM |
