Metal flears welding, the way to weld metal flears |
Aaron Cox |
Sep 16 2004, 06:07 PM
QUOTE(seanery @ Sep 16 2004, 12:35 PM) I have never done it....I'm afraid...I've seen wavy cars, mostly 911s. My buddy Paul had 930 flares welded onto his 75 Carrera (SC body) by kevin in Van Nuys area. He spot welded them and the result is fabulous...lemme see if I have a pic or two around... ive been to kevins. he had a 911 that i got the suspension off of. nice guy. |
Maltese Falcon |
Sep 16 2004, 09:27 PM
Advanced Member Group: Members Posts: 4,681 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Hey 9xauto , the flares (flear is a '60s bubble gum) go on good with a MIG welder with a .030 wire. You will not need to use the big shop type .035 wire spool. Use a mig with an external tank, as the types with flux built into the wire won't give you good consistent welds.
The shop that did mine used a heliarc (overkill), and then leaded and worked the seams to perfection. His work was 99.9 % perfect...and I've never undercoated the under sides of the flares, so I show his work off at shows ! I've seen some under sides of flares (most recently at GAF Ventura) that were totally unfinished and heavily oversprayed, most likely to disguise the unfinished work (IMG:style_emoticons/default/sad.gif) . Do your 914 up right...craftsmanship required on both sides ! MF |
SpecialK |
Sep 17 2004, 09:44 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
QUOTE(914forme @ Sep 16 2004, 12:20 PM) We have jetfighter that have velcroed on wing sections. (IMG:style_emoticons/default/bs.gif) |
SLITS |
Sep 17 2004, 11:00 AM
My Stealth bomber is all velcroed. That way I can land, rent a car, put it in the trunk and hide it from the Ruskys. <_<
phantom914 |
Sep 17 2004, 11:28 AM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
QUOTE(Special_K @ Sep 17 2004, 07:44 AM) QUOTE(914forme @ Sep 16 2004, 12:20 PM) We have jetfighter that have velcroed on wing sections. (IMG:style_emoticons/default/bs.gif) Hey, how can you comment. Have you seen his jetfighter to know that it doesn't have velcro? Andrew |
9xauto |
Sep 17 2004, 12:16 PM
Newbie Group: Members Posts: 17 Joined: 13-September 04 From: New York Member No.: 2,751 |
Thank you to all participants! The information I've received is better than buying a book. And yes I'm an asshole for misspelling FLARES. (IMG:style_emoticons/default/wub.gif)
SpecialK |
Sep 17 2004, 12:17 PM
QUOTE(phantom914 @ Sep 17 2004, 09:28 AM) QUOTE(Special_K @ Sep 17 2004, 07:44 AM) QUOTE(914forme @ Sep 16 2004, 12:20 PM) We have jetfighter that have velcroed on wing sections. (IMG:style_emoticons/default/bs.gif) Hey, how can you comment. Have you seen his jetfighter to know that it doesn't have velcro? Andrew Good point Andrew! Some even use rubber bands to hold the wings on....you know, the one's that say "Cox" on the side. (IMG:style_emoticons/default/biggrin.gif) |
phantom914 |
Sep 17 2004, 12:20 PM
QUOTE(Special_K @ Sep 17 2004, 10:17 AM) QUOTE(phantom914 @ Sep 17 2004, 09:28 AM) QUOTE(Special_K @ Sep 17 2004, 07:44 AM) QUOTE(914forme @ Sep 16 2004, 12:20 PM) We have jetfighter that have velcroed on wing sections. (IMG:style_emoticons/default/bs.gif) Hey, how can you comment. Have you seen his jetfighter to know that it doesn't have velcro? Andrew Good point Andrew! Some even use rubber bands to hold the wings on....you know, the one's that say "Cox" on the side. (IMG:style_emoticons/default/biggrin.gif) Smartass!!!!!!! Andrew ( (IMG:style_emoticons/default/biggrin.gif) ) |
Aaron Cox |
Sep 17 2004, 12:57 PM
QUOTE(phantom914 @ Sep 17 2004, 11:20 AM) QUOTE(Special_K @ Sep 17 2004, 10:17 AM) QUOTE(phantom914 @ Sep 17 2004, 09:28 AM) QUOTE(Special_K @ Sep 17 2004, 07:44 AM) QUOTE(914forme @ Sep 16 2004, 12:20 PM) We have jetfighter that have velcroed on wing sections. (IMG:style_emoticons/default/bs.gif) Hey, how can you comment. Have you seen his jetfighter to know that it doesn't have velcro? Andrew Good point Andrew! Some even use rubber bands to hold the wings on....you know, the one's that say "Cox" on the side. (IMG:style_emoticons/default/biggrin.gif) Smartass!!!!!!! Andrew ( (IMG:style_emoticons/default/biggrin.gif) ) I own cox airplanes , you should see our newest model, full size. called the 'big cox' |
phantom914 |
Sep 17 2004, 01:00 PM
QUOTE(acox914 @ Sep 17 2004, 10:57 AM) ............................... the 'big cox' So that is what you are interested in..... Andrew |
airsix |
Sep 17 2004, 01:46 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
You guys are a riot. Keep going.
-Ben M. |
Series9 |
Sep 18 2004, 09:26 PM
Here's a couple of pics of mine going on. I have a TIG welder and really think that's the way to go. You have full control. Cut carefully, weld slowly.
Attached thumbnail(s) |
Series9 |
Sep 18 2004, 09:27 PM
more
Downunderman |
Sep 19 2004, 04:11 AM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
WTG 914 and use 0.9mm mig wire for filler rod.
J P Stein |
Sep 19 2004, 07:08 AM
There is a weld wire called "Easy Grind" specifically made for welding auto sheet metal. It is "softer" than your normal 6000/7000 serise weld metal. ....also available in .025 dia.
A buddy got me some from a welding supply house. Wurks good. He kept the spool, but now that I have a welding machine, I'm gonna get it back. |
buck toenges |
Sep 19 2004, 08:27 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
Here is how I welded my flares on to my 914. Take the flares and place them over the original quarter panel. After lining up the flare on the body drill holes for sheet metal screws to attach the flares to the body. Drill the holes about 1/4 inch from the edge of the flare which will also drill holes into the body. This will hold the flare in the correct position to the body. Now cut both the flare and body with an air saw about 1/8 inch from the edge of the flare. You will cut both the flare and body at this point and have a perfect "jigsaw" effect. You then go and "spot" weld the flare to the body. It is quite easy. The only thing that makes it tough is the lip on the bottom of the flares and the body. You need to remove the right angle lip on the body so the flare "butts" up correctly when you line up the flares on the body. Sorry no pictures.
Maltese Falcon |
Sep 19 2004, 03:40 PM
Hey 9Xauto, When you're all done hangin the flares don't be alarmed if the L & R rocker panels are not exactly matching up to your new fenders (down at the bottom corners). Due to variations in fenders, bodywork and heat during welding, I've found that the side rockers usually need to be cut and re-worked to the proper length. Since most GT rockers are fibreglass it's a simple deal. (IMG:style_emoticons/default/biggrin.gif)
der Falkon |
Series9 |
Sep 20 2004, 08:09 PM
IronHillRestorations |
Sep 21 2004, 07:08 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
QUOTE(Maltese Falcon @ Sep 16 2004, 07:27 PM) I've seen some under sides of flares (most recently at GAF Ventura) that were totally unfinished and heavily oversprayed, most likely to disguise the unfinished work (IMG:style_emoticons/default/sad.gif) . Do your 914 up right...craftsmanship required on both sides ! Ask Sir Andy if he liked the way I welded the flairs on John Swanson's blue car. BTW, I use 024 wire, not 030. PK (IMG:style_emoticons/default/cool.gif) |
East coaster |
Sep 21 2004, 08:29 AM
Senior Member Group: Members Posts: 1,687 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
914RS.......Are they AA flares or factory GTs? I'm curious how you made the bottoms fit?
Lo-Fi Version | Time is now: 31st May 2024 - 11:04 PM |
