How well does your hood fit? |
Jeff Krieger |
May 5 2003, 04:13 PM
Unregistered |
The front and rear trunk lids on my car sit about 1/4 inch high all the way around. Do yours fit flush?
(IMG:http://persweb.direct.ca/aschwenk/F1040001.jpg) |
ArtechnikA |
May 5 2003, 04:27 PM
QUOTE(Jeff Krieger @ May 5 2003, 02:13 PM) The front and rear trunk lids on my car sit about 1/4 inch high all the way around. Do yours fit flush? <IMG>http://persweb.direct.ca/aschwenk/F1040001.jpg</IMG> of course. nice of Alfred Schwenk to host your images for you ... |
Jeff Krieger |
May 5 2003, 04:48 PM
Unregistered |
Yeah, he's a great guy. (IMG:style_emoticons/default/biggrin.gif)
May 5 2003, 05:02 PM
Resident German Group: Admin Posts: 41,580 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Alfred,
the hoods are adjustable. loosen the nuts where the hood is attached to the hinges, move the hood up/down. loosen the lock and adjust that too. make sure you don't have any rubber seals that stick up. ops, my bad, look next post further down for correction ... same for the front/back hoods. Andy This post has been edited by SirAndy: May 5 2003, 06:02 PM |
Aaron Cox |
May 5 2003, 05:03 PM
what wheels are on the car in question? they look like your typical trailer wheels....
Jeff Krieger |
May 5 2003, 05:19 PM
Unregistered |
QUOTE(SirAndy @ May 5 2003, 04:02 PM) Alfred, the hoods are adjustable. loosen the nuts where the hood is attached to the hinges, move the hood up/down. loosen the lock and adjust that too. make sure you don't have any rubber seals that stick up. same for the front/back hoods. Andy Thank you, Andy. ( I suppose that I should read the factory manual more). |
Jeff Krieger |
May 5 2003, 05:21 PM
Unregistered |
QUOTE(acox914 @ May 5 2003, 04:03 PM) what wheels are on the car in question? they look like your typical trailer wheels.... Somebody said they're American Racing wheels. Anyone want to make an even trade for four original Fuchs? (IMG:style_emoticons/default/tongue.gif) |
Lawrence |
May 5 2003, 05:47 PM
Huh?
QUOTE the hoods are adjustable. loosen the nuts where the hood is attached to the hinges, move the hood up/down. loosen the lock and adjust that too. make sure you don't have any rubber seals that stick up." I thought the nuts on the hood were to adjust the hood side/side, and fore/aft. Please, correct me if I'm wrong. (IMG:style_emoticons/default/confused24.gif) -Rusty |
May 5 2003, 05:51 PM
actually, it's where the hood-hinge is attached to the body where you do the up/down adjustement ...
NOT where the hood attaches to the hinge ... Andy |
Lawrence |
May 5 2003, 05:59 PM
QUOTE actually, it's where the hood-hinge is attached to the body where you do the up/down adjustement ... I've never looked there for a place to adjust. Thank you, Andy! -Rusty |
markb |
May 5 2003, 06:16 PM
I've never noticed either. Thanks!
mskala |
May 5 2003, 07:25 PM
R Group: Members Posts: 1,923 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Also, you can't really adjust side-to-side with the bolts on the hinges. The
slot really is elongated only for adjustment front to back. But you can make it or unmake it cockeyed by moving them a different amount. Mark S. '70 914-6 |
Lawrence |
May 5 2003, 08:00 PM
KaptKaos |
May 5 2003, 09:20 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Sounds like a personal problem to me.
Too much information. - Joe 73 1.7 |
Lo-Fi Version | Time is now: 28th March 2024 - 04:33 AM |
