San Diego: Porsche 912 / 356 Parts (bonita) $1 |
914World |
Mar 5 2012, 01:46 PM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
I have several porsche parts in thier ORIGINAL PACKAGING!!
Ring Set (yes all 4) for the big Bore 86P's Made in Japan #PR1465 $25.00ea. set (actually I have 2 sets.) Several (3) Mahne oil filters, 4.00 each 4 Bosch W5AC spark plugs, $ 1.00 each Clutch cable 6MM ENDS $ 10.00 German 10X965 fan belt. 4.00 German Belt 10x740 $4.00 And a engine block FACE PLATE only, with no serial numbers .Takes the press in seal. SHOULD FIT 356b/356c/912 Probably fit earlier 356a $100.00 German Sachs replacement pilot bearing #111.105.313A for the gland nut, $5.00 Also some new and some used Lug Nuts 2.00 Each And a used 912 cam shaft with no gear. 20.00 Heater box to body air tube $5.00 912 Speedo shows 58000 miles green numbers $25.00 Generator pulley both halves and the nut and washer and shims all $30.00 2 used gas springs about 13" length $7 each 1 Carb kit 616.108.902.02 $12.00 3 air filters Mahne for Solex $5.00 each Both German Elring Crank seals with Hi Temp Viton for the Main both for $12.00 If it is still listed it is still available. I update as they sell mike 619.204.38 zero zero If the ad is here, their still available, i edit as they sell i DO NOT TEXT
View the full article THIS IS NOT A 914WORLD AD! Do not reply to this thread! No one is listening! Click on the "View the full article" link above to go to the actual Ad! |
Lo-Fi Version | Time is now: 21st May 2024 - 12:19 PM |
