Using Subaru FI Parts |
ThinAir |
Sep 16 2004, 09:12 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Ben M. mentioned that he used Subaru 1.8L injectors in his Turbo 914 setup.
http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=17090 Seems like I heard someone say here that our injectors were NLA from Bosch. If need be, can we use Subaru injectors? What else can we use? I know there are alternatives like Megasquirt to replace your entire FI setup, but it would be good to know if there are alternatives by swiping parts from other makes. |
Mike9142.0 |
Sep 16 2004, 09:16 PM
Member Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region |
What are you up to now?
ThinAir |
Sep 16 2004, 09:18 PM
Absolutely nothing! Just wondering... although I wonder sometimes about the FI on the '75 Bus! It's just good to have a backup plan when things need fixing.
rick 918-S |
Sep 16 2004, 10:36 PM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I used 1984 BMW 533 injectors on my stock 1972 1.7 No real problems noticed.
airsix |
Sep 16 2004, 11:16 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(ErnieDV @ Sep 16 2004, 07:12 PM) Ben M. mentioned that he used Subaru 1.8L injectors in his Turbo 914 setup. http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=17090 Seems like I heard someone say here that our injectors were NLA from Bosch. If need be, can we use Subaru injectors? What else can we use? I know there are alternatives like Megasquirt to replace your entire FI setup, but it would be good to know if there are alternatives by swiping parts from other makes. Ernie, I don't know if you could get these injectors to work properly with the D-jet injection. I'm using aftermarket EFI and can tune to whichever injectors I choose. D-jet has some flexibility, but probably not enough to do that kind of injector swap easily. These Subaru (Nippon) injectors are actually rated for a lower flow than the standard 914 D-jet injectors. Now that i'm running the turbo I've maxed them out and I'm about to switch back to 2.0 D-jet injectors. -Ben M. |
Mike D. |
Sep 16 2004, 11:29 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I never got a confirmed part number on this, but some Jags run green bosch injectors that are the exact size and shape of the ours. I took some from the junk yard but never did anything with them.
-Mike D. |
Lo-Fi Version | Time is now: 31st May 2024 - 11:09 PM |
