Koni fronts adjusting question, I don't have the ones with the knob |
jim912928 |
Sep 17 2004, 07:09 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
In reading a few other threads on koni reds, I'm getting the impression that all of them are adjustable. Mine came with a 911 suspension off of a 71 911T. Mine do not have the knob that you can install on the tops to adjust. So, how exactly do you adjust these (thinking this is also why my front end seems so harsh).
Thanks as usual! Jim |
michelko |
Sep 17 2004, 07:57 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Attached thumbnail(s) |
michelko |
Sep 17 2004, 07:58 AM
and this
michelko |
Sep 17 2004, 07:59 AM
and this
rhodyguy |
Sep 17 2004, 08:06 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you have to take them free from the upper mount, push the rod in and rotate it. i think you will feel 3 clicks. alot of work to change the settings.
kevin |
SLITS |
Sep 17 2004, 09:22 AM
No clicks - you just feel the engagement of the adjusting mechanism. As I remember, it is like 7 turns from soft to hard. You have to pick where you want them. You have the "collapse to adjust". You will see an arrow on the body of the cartridge that has "Heavy" printed above it. Yada Yada Yada.
Lo-Fi Version | Time is now: 31st May 2024 - 09:55 PM |
