This car worth 6k?, Ebay link |
davidcalvin |
Sep 19 2004, 03:16 PM
Member Group: Members Posts: 200 Joined: 31-August 04 From: California Member No.: 2,662 |
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...2489744200&rd=1
It looks nice. Drives well. And is well documented. Claim is that its original miles, 58k. No rebuild on the engine or tranny I believe. Its all original. even has the original radio (blaupunkt) What say yall? |
tod914 |
Sep 19 2004, 04:10 PM
I think that is one of the member's cars here. Think he was moving to Spain if it's the same person. Looks like a nice car. Maybe take it somewhere for a PPI to check everything if you can. Seems like a good price.
davidcalvin |
Sep 19 2004, 04:13 PM
Actually.. no. The story on this one is that it was owned by a dentist in burlingame. The man died a few years ago and his son recently sold the car to the person who is selling it now on ebay.
It all seems nice. I just worry that the engine hasnt been rebuilt. But if the miles are original then maybe its good for another 30k ish. Thanks. |
tod914 |
Sep 19 2004, 04:46 PM
I purchased my car with 42K on it. It has 60K on it now. Engine runs real strong. If you have a proper inspection done, doing a compression and leak down, that should give you a good idea on where the motor is at. Probally not having a rebuild is a good thing with that kind of milage. You need to go over the car with a fine tooth comb. Check, the obvious, fit and finish, rust ect. But also, inspect bushings, brakes, shocks, springs, exhaust, test mps if you can. And, all electrical functions. All these items can effect the overall value. Which in turn, make it a good deal, or car you will have to sink alot of time and money into. PM me your number if you need any tips on inspecting the body. Can't offer much help on the mechanical side of things. But, plenty of other friendly folks here can.
anthony |
Sep 19 2004, 07:38 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
QUOTE It all seems nice. I just worry that the engine hasnt been rebuilt. But if the miles are original then maybe its good for another 30k ish. Overall condition is much more important than worrying how many miles you'll get out of an engine. And just for comparison sakes I've got 160K on my original engine and it doesn't smoke, leak, and still has good compression. |
Porsche Rescue |
Sep 19 2004, 07:47 PM
Car looks good and my be well be worth $6000 but I'm guessing that it is 158K, signed statements or not.
tod914 |
Sep 19 2004, 08:18 PM
If the correct milage is deciding factor for you, you might be able to determine that depending upon when and where the car was serviced. Might even be able to contact the shop who worked on it. No garruntee of course. Look at the pedals, steering wheel and drivers seat. They should be alittle more worn on a car with 150 as opposed to a car with 50. Check the carpet wear as well. Certianly looks nice in the photos. But that can be decieving. Good luck!
EdwardBlume |
Sep 19 2004, 09:52 PM
Looks good. Go for it!
gregrobbins |
Sep 19 2004, 10:15 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
If you are worried about the motor, take it to a mechanic of your choice and have a compression and bleed down test preformed. That will tell you tons about the motor. Everything else looks good on the car. If the motor is good, the value is there.
GWN7 |
Sep 20 2004, 01:49 AM
well someone thought it was worth 6k........sold
GaroldShaffer |
Sep 20 2004, 07:33 AM
I know this car is sold, but just one of the things I check when looking at "low Mileage" older cars is the wear on the pedals you can see the difference in wear patterns between new (0 miles) - old (150k mles). There are many other factors but it takes a lot of use to wear down the rubber on the pedals.
meursault |
Sep 21 2004, 12:19 AM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
QUOTE I know this car is sold, but just one of the things I check when looking at "low Mileage" older cars is the wear on the pedals you can see the difference in wear patterns between new (0 miles) - old (150k mles). There are many other factors but it takes a lot of use to wear down the rubber on the pedals. But considering that those rubber pedal pads cost somewhere in the $5 range, I wouldn't depend on that indication too much. Also it's something you could quickly change out if you had a parts car with better looking pads. |
davidcalvin |
Sep 21 2004, 12:43 AM
Well.. it was me. I bought it. Been driving it all day and it is really awesome. It shifts so tight and it hauls a$$. I love it. Everything works on it. Its so cool.
The down side is.. after it gets warm, some smoke starts coming out of the engine compartment. Smells like oil burning or maybe belt rubber or something... sigh. I guess nothing go be perfect... So. I'll be taking to in and having "them" check it out. Still, its a sweet car. I just hope the engine is cool. Thanks all for your feedback. David |
tod914 |
Sep 21 2004, 08:08 AM
Maybe its just oil on the heat exchangers/engine. Clean all that off before you take it to a shop so they can see where any leaks are comming from. Congrads! Looks like a sweet ride. (IMG:style_emoticons/default/beerchug.gif)
davidcalvin |
Sep 21 2004, 10:06 AM
That makes sense, I guess. I dont see the smoke until the engine is hot (After awhile driving). But the temp guage is within normal limits.
Thanks for all the help. This board is totally cool. If it hadn't been here I probably wouldnt have bought the car. (IMG:style_emoticons/default/pray.gif) David |
carreraguy |
Sep 21 2004, 12:15 PM
It's not your dad's 914! Group: Members Posts: 1,197 Joined: 17-October 03 From: San Jose, CA Member No.: 1,256 Region Association: Northern California |
Welcome to the club David! Its nice to have another "big bumper " car in the group. You ought to bring it to the 9;14 Breakfast (see Jeff's thread below) this Saturday so we can all see it and we compare notes with my low mileage '76er.
davidcalvin |
Sep 21 2004, 12:20 PM
Thanks for the welcome..
I'll try to make it there. It'll be cool to see a whole bunch of 914s in one place. Kinda like driving down the street at HPH :-). I am not convinced the mileage on mine is original. I'd welcome the opinions of the breakfast-attending experts. David |
Brad Roberts |
Sep 21 2004, 10:46 PM
David,
I went over that car pretty well. I personally believe the mileage is correct. Lots and lots of little things we look for that clues us in to actual mileage. I see a LOT of cars come and go through the shop... lots of little differences between 50k and 150k. The person you bought the car from is a up and up guy. He brings all his Porsche related work to us. B |
davidcalvin |
Sep 21 2004, 11:13 PM
Thanks Brad,
I love the car so far. I should have had it inspected though, but I felt comfy since HPH did the service for it. Its smoking out of the engine compartment. Smells like burning oil. Need to bring it in to get it checked out. David |
Brad Roberts |
Sep 21 2004, 11:19 PM
Ask him for the service invoices. We ALWAYS notate what the car needs on the repair orders.
Some of the MAJOR issues with buying a low mileage car: all the fuel lines are normally rotted all the brake lines need to be done all the rubber hoses associated with the engine will be dry rotted all the rubber seals will be dry The VERY worst thing you can do to any car is let it sit. I'm betting the burning oil is something easy. He called us today and told us you traded or bought the car from him. B |
Lo-Fi Version | Time is now: 16th May 2024 - 01:42 AM |
