| ruddyboys |
Sep 20 2004, 05:40 PM
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
While on a test drive I notice there is alot of play in the clutch pedal, when its almost fully up is when it grabs. I tried to tighten the adjustment nut by the fork and no change. When I had the trans off the clutch pad looked pretty good. Whats up with this.
| smrz914 |
Sep 20 2004, 05:53 PM
Soon to be brightening the life of the person behind you. ![]() ![]() Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
By tightening the nut you are engaging the clutch. It's like stepping on the pedal. Back off on the nut. You want the clutch to disengage later.
| ruddyboys |
Sep 20 2004, 06:20 PM
I will give it a try.
| jr91472 |
Sep 20 2004, 06:24 PM
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Ruddyboys, please post your results. i too am having some difficulty with what should be a simple adjustment (can't seem to wrap my brain around it (IMG:style_emoticons/default/wacko.gif) )
Look forward to your next post. |
| Andyrew |
Sep 20 2004, 06:31 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I had a huge problem of my clutch always not being in adjustment...
Adjust it one week, and have to adjust it again (tighter) the next. Result? Well lets just say that with this other clutch in my v8, I set it to an inch play (more like 2... have to chop off the clutch cable threads to get a little more in to set it in the disengage in the middle more) in the clutch, ie pull back the clutch and it goes twards you an inch, and its shifting disengaging/engaging GREAT! NO more grinding.. EVEN while the idle is at 2k!!!! |
Lo-Fi Version | Time is now: 14th April 2026 - 04:36 PM |
