Fog light question |
auto_cran |
Mar 18 2012, 09:16 PM
Member Group: Members Posts: 56 Joined: 12-February 12 From: Dallas, Texas Member No.: 14,123 Region Association: None |
When we first picked got our '74 914 1.8 the fog lights worked upon initial inspection. Now, they don't.
When I pull the switch (key on, lowbeams on) the fog lights do not come on - but the switch lights up brightly. During inspection - I don't recall the switch lighting up - in fact, I didn't even know it did. Main concern was that the fog lights worked - which they did. Question: is the switch suppose to light up when the lights work - or does it light up when the lights don't work? (IMG:style_emoticons/default/confused24.gif) thanks! Chris |
Eric_Shea |
Mar 18 2012, 09:36 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
It lights up when you turn the lights on.
So... High beam switched on? Or, relay? |
auto_cran |
Mar 18 2012, 09:40 PM
It lights up when you turn the lights on. So... High beam switched on? Or, relay? Thanks Eric. I know its not the highbeams - I was switching the turn signal stalk back & forth. The relay is next. Ok - so anyone want to point me in the direction to where the relay is at? I sure have alot to learn about these cars! Chris |
Eric_Shea |
Mar 18 2012, 09:42 PM
On the fuse panel. Remove the screws and drop it down.
Meoshe |
Mar 19 2012, 06:29 AM
Newbie Group: Members Posts: 9 Joined: 21-December 11 From: Huntington Beach Member No.: 13,921 Region Association: Southern California |
It lights up when you turn the lights on. So... High beam switched on? Or, relay? Thanks Eric. I know its not the highbeams - I was switching the turn signal stalk back & forth. The relay is next. Ok - so anyone want to point me in the direction to where the relay is at? I sure have alot to learn about these cars! Chris You didn't mention it so I thought I would ask, did you check the fuse to see if it blown. |
auto_cran |
Mar 19 2012, 06:36 AM
Thanks for all the replies. I'll pull out the fuse panel and check the relays.
Meoshe - yes, the fuse was the 1st thing I checked. It's fine. Chris |
Lo-Fi Version | Time is now: 6th June 2024 - 04:03 PM |
