jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Like the title says, what year 911 flywheel do I need so my 2.4 6 will bolt up to my 901?
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
You will need the one that is for a 2.0 6 motor. Like an early 911 or a real 914-6 would have.
Gonna get that motor going? |
jmill |
Gonna get that motor going? Trying. Picking up parts for it now. Have the carbs, manifolds and dizzy but still need the alt, shroud, fan and flywheel. After I get all the pieces I'll tear it apart and send it out for machining. Hopefully I can get by with just rings and honing. If not I'll have to slam on the brakes until I have the funds for new p/c's. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
You can use a stock 914-6 flywheel. But there's a difference in the timing marks and TDC will be off, due to the difference in the crank of the 2.4. I took back a "bad" new flywheel years ago, that was used on a 2.4, and found out there's a difference.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
yep.. from a 2.0/6 motor
so 911: 1965 1966 1967 1968 1969 or 914/6: 1970 1971 1972 |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,619 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
It's a six bolt flywheel that bolts up to 2.7 liter engines and smaller.
brant |
zig-n-zag |
Member ![]() ![]() Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 ![]() |
The 914 uses a 215mm clutch, so the last year a 911 used a
215mm clutch was 1969 (901 flywheel). 1970 was the first year of the 225mm clutch (915 flywheel?). |
Steve |
I meant to say you can use the 911 2.0 six bolt flywheel on 2.7 liter engines and smaller. Starting with the 2.2 motors they went with a 225mm pull type clutch. The 2.0 flywheel works on engines up to 2.7 liters and allows a stock push type clutch for use with the 901 trans.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,541 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
You can also use a "915" flywheel (225mm) IF you use a 70 or 71 911 clutch disk and the pull type arm from a 70 or 71 911. It will also involve moving the pivot point inside the 901 bell housing to accommodate the different length of the arm.
The advantages are that you can use a straight cable with no pulley on the transmission to work the clutch. And don't anyone say this doesn't work, as I ran it on my car for 2 years. |
Steve |
You can also use a "915" flywheel (225mm) IF you use a 70 or 71 911 clutch disk and the pull type arm from a 70 or 71 911. It will also involve moving the pivot point inside the 901 bell housing to accommodate the different length of the arm. The advantages are that you can use a straight cable with no pulley on the transmission to work the clutch. And don't anyone say this doesn't work, as I ran it on my car for 2 years. Or you can just swap your trans guts and rear cover with a 70 or 71 911 trans. I drove one with a 3.0 and I thought the clutch feel was night and day better than the KEP Stage 2, I am running with my 3.2. |
Lo-Fi Version | Time is now: 17th June 2024 - 05:42 AM |
