Los Angeles: 1970 PORSCHE 914 V8 CONVERSION (CORONA) $11000 |
914World |
Mar 24 2012, 07:32 AM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
1970 PROSCHE 914 V8 CONVERSION...GROUND UP RESTORATION.
* ORIGINAL CALIFORNIA CAR * FRESH CHEVY 350, 4 BOLT MAIN, 10.5:1 COMPRESSION * CHET HERBERT CAM (LUMPY) I HAVE SPECS IF YOU WANT THEM (SOUNDS MEAN AT IDLE) * PRO COMP 202 ALUMINUM HEADS * ROLLER ROCKERS * CUSTOMIZED COOLING SYSTEM WITH MEZZIER ELECTRIC REMOTE MOUNT, 55 GAL PER MIN WATER PUMP * PRO COMP ALUMINUM AIR-GAP INTAKE * EDLEBROCK 650 CARB * BILLET DISTRIBUTOR * POWDER COATED BLACK WIRE LOOMS TO MATCH THE BLACK POWDER COATED VALVE COVERS * MSD IGNITION * DUAL EXHAUST, CHROME TIPS, 3 CHAMBER FLOW MASTER * CUSTOM CENTER CONSOLE WITH WATER TEMP, OIL PRESSURE AND VOLT GAUGES * CUSTOM BILLET DASH INSERT * CD / HEAD UNIT WITH AX PORT FOR IPOD * CUSTOM FLOOR SPEAKERS AND SPEAKER COVERS * NEW CARPET * NEW HEADLINER UNDER THE TARGA TOP * LESS THAN 500 MILES ON ENGINE .40 OVER * ALUMINUM RADIATOR * CUSTOM BILLET GRILE TO ALLOW MORE AIR FLOW TO COOL RADIATOR * HIGH OUTPUT ELECTRIC FAN TO COOL RADIATOR * CUTOM BILLET RADIATOR SHROUD * 901 SIDE SHIFT TRANS / YES IT CAN HANDLE THE HORSEPOWER JUST CANT GET CRAZY OFF THE LINE. JUMP ON IT AT 2K PLUS RPM'S AND HOLD ON TIGHT. * 4-LUG RIVIERA RIMS WITH NEW TIRES * NEW WHEEL BEARINGS AND SEALS ALL THE WAY AROUND * NEW SHOCKS AND STRUTS * NEW PADS ALL THE WAY AROUND * NEW ROTORS ALL THE WAY AROUND * HAS BMW 3 SERIES FRONT CALIPERS * ALL NEW WIRING FROM STEERING WHEEL BACK * TACH HAS BEEN CONVERTED TO V8 SETTINGS / RECONDITION WITH NEW PAINT AND NEEDLE * NO RUST...HELL HOLE IS PERFECT. IT HAD A SMALL NICKLE SIZE RUST SPOT ON PASSENGER FLOOR. IT WAS GRINDED DOWN AND GLASSED OVER * NEW INTERIOR / BASKET WEAVE * NEW DOOR PANELS * JET BLACK PAINT (DUPONT BLACK WITH NO TONER), COLOR SANDED AND POLISHED THE CAR IS RUNNNG GREAT!!! SHE RECENTLY WON FIRST PLACE IN A CAR SHOW SPONSORED BY THE CELEBERTY CAR BUILDER, BARRY WHITE, FOR THE BEST FABRICATION. THE CAR IS A REAL HEAD TURNER. SUMMER IS COMING AND DRIVING THIS BEAST WITH THE TOP DOWN YOU WILL BE SURE TO TURN HEADS. 11K OBO 909/ 471-2432 EMAIL OR TEXT IS BEST EMAIL ME IF YOU WANT BUILD PICS
View the full article THIS IS NOT A 914WORLD AD! Do not reply to this thread! No one is listening! Click on the "View the full article" link above to go to the actual Ad! |
Lo-Fi Version | Time is now: 17th May 2024 - 05:59 AM |
