SOLD...FS Rear swaybar assembly (aftermarket) |
dlee1967 |
Mar 25 2012, 09:26 AM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
SOLD....Aftermarket rear sway bar for 914.(15.75mm) Part number stamped on the unit is 9146, (Weltmeister?) You will have to do a little research to see who the mfg is, but I am
sure someone will chime in here. This model has adjustable heim endes and includes all hardware including the special bolt that passes through the shock and trailing arm. The upper brackets were attached with four holes drilled through the trunk floor. $100 plus $24 for shipping as the box will have to be so big. thank you....David Lee |
Lo-Fi Version | Time is now: 24th May 2024 - 11:23 AM |
