| 9fourteen |
Mar 25 2012, 06:09 PM
Newbie ![]() Group: Members Posts: 42 Joined: 20-November 06 From: Cincinnati, OH Member No.: 7,239 Region Association: Upper MidWest |
I have finally started to rebuild my 74 914. I got my garage setup, tools ready, just need to find the time now. I figured I would start a thread to keep track of progress. I bounce around between many projects and usually busy on other things so I expect this to take many years.
Paid $900 for it and drove it home. I drove it a few times before it developed a serious oil leak and has been sitting in the garage ever since. I am finding a lot of hidden rust on this car. Typical spots but a lot that has been hidden by previous repaints and repairs. Hell hole is shot, outer longs in bad shape, floor pan needs repair, etc. Like I said, typical 914 rot. I am a complete beginner at this so it will be a learning experience all the way. I plan on doing it all myself and getting in way over my head. Here is a picture of the car as it was bought about 10 years ago. Attached image(s)
| 9fourteen |
Mar 25 2012, 07:11 PM
I decided to cut the quarter panel off all the way up into the sail to get get access to the HH and longs. Got it cut and all the spot welds drilled out and loose. The whole panel is loose except where that tube goes from the door jamb to the inner sail. I assume that is a vent tube. The tube is welded in so only solution I see to getting around that is to cut it around that tube. I need to get into that area because the strike plate and upper part of the finder is rotted out. I need to rebuild the whole area.
That is as far as I got this weekend. A week out of town for work and then hopefully back on it next weekend. Attached image(s)
9fourteen 1974 Restortaion/Build Thread Mar 25 2012, 06:09 PM
9fourteen The first repair I attempted was to rebuild the fr... Mar 25 2012, 06:13 PM
9fourteen hammered out a patch piece with a new support brac... Mar 25 2012, 06:17 PM
9fourteen I got it welded in. Not a perfect job but it works... Mar 25 2012, 06:35 PM
9fourteen With my first repair under my belt I am starting o... Mar 25 2012, 06:52 PM
dlo914 :wttc: Off to a good start! GL on the rest of ... Mar 25 2012, 07:10 PM
9fourteen Do I have enough support?
I am getting ready to s... May 23 2012, 09:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th January 2026 - 12:30 PM |
