914 Service Manual, My CD is damaged/need replacement files |
d7n7master |
Sep 27 2004, 12:22 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hi All,
I guess the cd is getting too scratched for my drive to open the pdf files. So I need to download the files again. I went to http://www.914world.com/downloads/ - but it says I'm not authorized to view files. Whatz up??? Thanks, Gary (IMG:style_emoticons/default/mad.gif) <_< |
d7n7master |
Sep 27 2004, 02:26 PM
(IMG:style_emoticons/default/icon_bump.gif) Help me Mr. Wizard!!!
But - failing that, what I'm looking for (this time) is a exploded view of the impeller hub assy. & the o'ring between the impeller hub & the crank seal. When I pulled the impeller hub off the old engine I found an o'ring behind it. I can't understand it's pupose. Maybe it's suppose to be a "dust seal"??? I don't know. Anybody know? Thanx, Gary Attached thumbnail(s) |
Sep 27 2004, 02:32 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(d7n7master @ Sep 27 2004, 11:22 AM) Whatz up??? directory indexing is turned off on the new server (and will stay off!) ... i have to find a different way to do this, (IMG:style_emoticons/default/idea.gif) Andy |
d7n7master |
Sep 27 2004, 02:52 PM
Bummer (IMG:style_emoticons/default/sad.gif) Guess I'll have to copy my copy...
Gint |
Sep 27 2004, 03:57 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE directory indexing is turned off on the new server (and will stay off!) ... i have to find a different way to do this In Apache, I had it turned off for just some directories via directives. Is something like that not possible with whatever your using for a web server on this box (I assume IIS, but...)? |
Sep 27 2004, 04:07 PM
QUOTE(Gint @ Sep 27 2004, 02:57 PM) In Apache, I had it turned off for just some directories via directives. Is something like that not possible with whatever your using for a web server on this box (I assume IIS, but...)? aha, i had to create a virtual directory to be able to set browsing individually ... just had to rename the real folder and create a virtual link to it. werks fine now! (IMG:style_emoticons/default/cool.gif) Andy |
d7n7master |
Sep 28 2004, 11:53 AM
Once again - saved by the 914Club. Got it, burned it, burned another, put one safely away...
Thanks a lot SirAndy/Brad (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) Now I can look for what this damned o'ring is for - I found it when I removed the impeller hub. Got me stumped. |
d7n7master |
Sep 28 2004, 12:19 PM
There's no o'ring in this view. I'll keep looking for other views - but now I'm thinkin' it's possible that the p.o added the o'ring so that the nasty ass permatex he globbed all over the crank seal would have something to "stick" to - (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 31st May 2024 - 10:24 PM |
