Want to go Bigger, Will it screw me up? |
Allan |
Sep 27 2004, 04:44 PM
I am in the process of re-building my motor and have been told to go to bigger P/C's. Will it throw off my FI? Let's say starting with 96mm. How big can I go without messing with the ECU? Please (IMG:style_emoticons/default/pray.gif)
Sep 27 2004, 04:58 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Headrage @ Sep 27 2004, 03:44 PM) I am in the process of re-building my motor and have been told to go to bigger P/C's. Will it throw off my FI? Let's say starting with 96mm. How big can I go without messing with the ECU? Please (IMG:style_emoticons/default/pray.gif) you can build a 2056 and use the stock FI, no problem. it's the non-stock CAMs that really throws off the FI ... (IMG:style_emoticons/default/wink.gif) Andy |
Allan |
Sep 27 2004, 05:21 PM
Gonna use the stock webcam for the time being. It should be good.
swood |
Sep 27 2004, 05:59 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Some have used the #73 grind, mild as it is with success. That's what I did, but havent fired it up yet. Im King Procrastonator! (IMG:style_emoticons/default/smilie_pokal.gif)
ChrisReale |
Sep 27 2004, 07:51 PM
you might have to have the MPS re-calibrated on a dyno to make sure you are getting proper Air/fuel mixture.
Bleyseng |
Sep 27 2004, 10:02 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Jake Raby |
Sep 27 2004, 10:30 PM
Stock cam= (IMG:style_emoticons/default/barf.gif)
You must want to fry eggs on your engine. The stock cam may run smooth with FI, but its the hottest thing on the planet for the heads. |
SpecialK |
Sep 27 2004, 10:42 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
QUOTE(Jake Raby @ Sep 27 2004, 08:30 PM) Stock cam= (IMG:style_emoticons/default/barf.gif) You must want to fry eggs on your engine. The stock cam may run smooth with FI, but its the hottest thing on the planet for the heads. Is there a better cam setup to run with a stock FI? (yeah Jake, I know how you feel about FI (IMG:style_emoticons/default/ar15.gif) ) |
Lo-Fi Version | Time is now: 31st May 2024 - 11:27 PM |
