Suspension Bushings, Where can I get rubber ones? |
scoobykvn |
Apr 1 2012, 05:43 PM
Member Group: Members Posts: 142 Joined: 6-July 06 From: columbus, ohio Member No.: 6,388 Region Association: Upper MidWest |
I am trying to find some reasonably priced rubber suspension bushing. I do not really want the stiffness of the poly ones, but they are so much cheaper than the only rubber ones I found. Any thoughts?
NORD |
Apr 1 2012, 06:35 PM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
Try Eric our local Brake Man, He also sells other parts for the car. I picked mine up from him. Try his site, a good vendor on the broad PMB Performance Eric Sheeeeeee (IMG:style_emoticons/default/driving.gif) |
Mikey914 |
Apr 1 2012, 07:56 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I make both versions for the rears the dash16 and dash 17s.
http://shop.914rubber.com/product.sc?produ...p;categoryId=-1 |
a914622 |
Apr 1 2012, 08:52 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Power flex bushings. The plastic transmits road noise like rubber , but works like a bushing.
Power flex north america Jcl |
Mikey914 |
Apr 1 2012, 11:23 PM
scoobykvn |
Apr 19 2012, 09:59 AM
Does anyone have squeaking problems using the poly control arm bushings?
TheCabinetmaker |
Apr 19 2012, 10:13 AM
scoobykvn |
Apr 19 2012, 10:33 AM
Does anyone have squeaking problems using the poly control arm bushings? Yes! I had to drill and tap and insert some grease Zerks and fill the tube. Do you have to regrease them often to keep them from squeaking? Someone needs to make cheaper rubber replacements for the daily drivers. |
TheCabinetmaker |
Apr 19 2012, 11:57 AM
I had to regrease once about a week later, but its been good for about7 months (about 9000 miles
Lo-Fi Version | Time is now: 16th May 2024 - 03:12 PM |
