Oil temp gauge screwy, At least I think... |
ThePaintedMan |
Apr 3 2012, 11:00 AM
Hello all,
I've searched this topic already, so I'm pretty sure I know whats up. I ordered a set of VDOs, per your suggestions and started wiring them up. Right now, the CHT is in and working (haven't seen temps over 325 yet, which is very cool!) but the oil temp gauge is giving me problems. I am using a billet taco plate made by a gentleman in the UK with a VDO sender. Everything seems to be wired correctly, as the needle does move off its resting position after several minutes. However, I haven't seem oil temps over 130 degrees yet and this is after driving the car about 10 miles at a time. Is it possible I have the wrong sender for the gauge? I ordered them from egauges.com which I believe got the order correct. Unfortunately I'm not sure if I still have the box for the sender to verify the ohms. Would a mismatched sender yield lower temp readings? How about thread tape? Can't remember if I put any on the sender threads... Maybe my engine just simply runs this cool, but 130 degrees sounds pretty darn low. Thanks gents! |
Lo-Fi Version | Time is now: 29th May 2024 - 07:00 AM |
