Where does this washer go? |
siverson |
May 7 2003, 01:17 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Hi,
I'm in the middle of reassembling my 914's rear suspension... After reviewing the factory manuals, it looks like there a washer back there I've never used. Does this washer go on the outside of the suspension console "ear", or on the inside, in between the ear and the trailing arm? Thanks for any tips. -Steve Attached image(s) |
Mueller |
May 7 2003, 01:22 PM
Hey Steve,
It would have to go on the outside of the inside tab (engine side), of all of the tabs that I have seen, they have the knurled impresssion from the axle. Unless the washer was intended for use due to damage or something odd like that. Make sure you have enough threads for the nut if using the washer |
Lo-Fi Version | Time is now: 20th May 2024 - 05:40 AM |
