Optima blew out...... took the temp gauge with it............., Battery shorted out on its own........couple of issues |
avidfanjpl |
Apr 10 2012, 02:45 AM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
19 Months and one day Orangina will not start, and I mean no lights of any kind. Got my Schumacher charger out, and it said it had a short in the Optima battery.
Now the directional switcher doesn't work in the tack, the center console clock and voltmeter are fine. The temp gague stopped working. I have one of those $40 temp gauge that is the oil stick, and on Sunday, a hot day, I took it at 2 for a 65 mile jaunt across LA and SBDO. Temp stayed at 225. Any ideas on the gauge or the tach directional box? Think that is on the inside of the fuse panel. THANKS! John |
Bartlett 914 |
Apr 10 2012, 06:33 AM
19 Months and one day Orangina will not start, and I mean no lights of any kind. Got my Schumacher charger out, and it said it had a short in the Optima battery. Now the directional switcher doesn't work in the tack, the center console clock and voltmeter are fine. The temp gague stopped working. I have one of those $40 temp gauge that is the oil stick, and on Sunday, a hot day, I took it at 2 for a 65 mile jaunt across LA and SBDO. Temp stayed at 225. Any ideas on the gauge or the tach directional box? Think that is on the inside of the fuse panel. THANKS! John sounds like t alternator / voltage regulator failed. this destroyed everything. i don't think the battery is the cause. |
underthetire |
Apr 10 2012, 08:32 AM
Common failure in the Optima's actually. Plates break loose=short=takes out the charging system. It's the Red Tops that do this BTW.
Woody |
Apr 10 2012, 08:54 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
FWIW you're supposed to use a AGM type charger on an optima.
jcambo7 |
Apr 10 2012, 09:09 AM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
ChrisFoley |
Apr 10 2012, 11:02 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Absorbed Glass Mat
unpolire |
Apr 10 2012, 12:32 PM
Member Group: Members Posts: 51 Joined: 6-July 08 From: Los Angeles CA Member No.: 9,260 Region Association: Southern California |
Common failure in the Optima's actually. Plates break loose=short=takes out the charging system. It's the Red Tops that do this BTW. I have had 4 red-top and 1 yellow-top Optima fail repeatedly. Unrelated to car issues. I have an AGM (Absorbent Glass Mat)-compatible electronic charger, but that is not the issue. When they go they will not accept a charge, period. Very frustrating as I thought I was buying the best for $180-$220+. I have seen a brand new one fail in 30 days, verified by the distributor. Amazingly, when you have a good one, they are apparently invincible. Distributor showed me one that has never been charged in 8 years and had perfect voltage. Production switched outside of the USA and this could be the problem with internal quality. |
Elliot Cannon |
Apr 10 2012, 01:26 PM
Common failure in the Optima's actually. Plates break loose=short=takes out the charging system. It's the Red Tops that do this BTW. I have had 4 red-top and 1 yellow-top Optima fail repeatedly. Unrelated to car issues. I have an AGM (Absorbent Glass Mat)-compatible electronic charger, but that is not the issue. When they go they will not accept a charge, period. Very frustrating as I thought I was buying the best for $180-$220+. I have seen a brand new one fail in 30 days, verified by the distributor. Amazingly, when you have a good one, they are apparently invincible. Distributor showed me one that has never been charged in 8 years and had perfect voltage. Production switched outside of the USA and this could be the problem with internal quality. That last sentence pretty much sums it up. (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/headbang.gif) |
Cracker |
Apr 10 2012, 03:08 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Too funny. I just replaced my Red top this morning...funny things were happening!
a914622 |
Apr 10 2012, 10:14 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
The first red top i had laster 8 years starting the little diesel,porsche,dozer, what ever.
The second one lasted 60 days in the toyota 4x4. A missed Q with a stump jar-ed the battery hard enough to break one of the plates loose and fried it. I have heard rumors a hard drop on the counter at the parts store will bugger them up? Chin-Sing quality. jcl |
rfuerst911sc |
Apr 11 2012, 03:43 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have a yellow Optima that is acting up, it is less than 2 years old.
okieflyr |
Apr 11 2012, 05:18 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I've got a red top that gets used in a car on occasion, but mostly floats around the garage and gets called upon to jump the kids cars. I use an old fashion charger on it 1-2 times a year to top it up. It is 7+ years old and still works fine. Guess I've been lucky...
Tom_T |
Apr 11 2012, 06:44 PM
This is why they shortened the warranty to just 24 mos. IIRC about 2-3 years ago - when they combined with Interstate (another formerly invincible battery - don't know who bought out who), moved production elsewhere & cut warranties - just selling off the former good name apparently! (IMG:style_emoticons/default/sad.gif)
Bad Luck John! (IMG:style_emoticons/default/sad.gif) Text me when you're going to AX the dark knight next! Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Socalandy |
Apr 11 2012, 07:25 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
had my yellow top 5 years and running with no tender and sadly sat for 3 months at one point without even a start. Still cranked up no problem (IMG:style_emoticons/default/smilie_pokal.gif)
greenie |
Apr 11 2012, 07:48 PM
Senior Member Group: Members Posts: 873 Joined: 26-October 04 From: Trinidad Member No.: 3,013 Region Association: Pacific Northwest |
Common failure in the Optima's actually. Plates break loose=short=takes out the charging system. It's the Red Tops that do this BTW. I have had 4 red-top and 1 yellow-top Optima fail repeatedly. Unrelated to car issues. I have an AGM (Absorbent Glass Mat)-compatible electronic charger, but that is not the issue. When they go they will not accept a charge, period. Very frustrating as I thought I was buying the best for $180-$220+. I have seen a brand new one fail in 30 days, verified by the distributor. Amazingly, when you have a good one, they are apparently invincible. Distributor showed me one that has never been charged in 8 years and had perfect voltage. Production switched outside of the USA and this could be the problem with internal quality. (IMG:style_emoticons/default/agree.gif) My experience is that these batteries do not stand up to recharging, if you do not use the car regularly and keep the battery near full charge they do not last. I've spent to many $$ on Optimas and seen no benefit for the extra money. The last one I purchased would not hold a charge. I'm not buying them again. |
Lo-Fi Version | Time is now: 28th May 2024 - 04:39 PM |
