Oil Cap |
Oil Cap |
timothy_nd28 |
Apr 11 2012, 04:43 PM
I have been going thru my 1.8L engine in a attempt to rid all potential vacuum leaks. The L-jet is very sensitive to the slightest vacuum leak. Why is there a hole in my oil cap? (IMG:style_emoticons/default/WTF.gif)
partwerks |
Apr 11 2012, 10:43 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Don't know, but I'd plug it with something like a small screw maybe.
1.8 usually needed to replace the O ring under the cap. |
timothy_nd28 |
Apr 11 2012, 10:51 PM
I already installed the secret seal kit for the oil cap, 2 new o-rings. The tiny hole looks original, almost like the factory intended it to be there.
jonferns |
Apr 16 2012, 09:53 AM
Mine also has the little hole
john rogers |
Apr 16 2012, 10:24 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
It is a small vent to allow water vapor or even steam to vent so that the oil filler does not get that "white mung" that many 911 oil filler necks get due to moisture build up. Even though the PCV valve is there at the filter box there are times when no flow is taking place.
timothy_nd28 |
Apr 16 2012, 10:32 AM
I'll admit this, I had the oil fill assy off, and I put my thumb over the oil hose port, and put my mouth over the bottom, to create a vacuum. I was surprised of how much vacuum leak I had while sucking on the filler neck! That tiny hole may look unsignificant, but being I have a Ljet system, it worry's me.
Lo-Fi Version | Time is now: 14th May 2024 - 09:59 PM |
