JB Weld? |
JB Weld? |
MarkG |
Oct 4 2004, 09:31 AM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
One of the air injectors on my 2.0 '76 has striped threads; it screws in but will not tighten....don't want to heli-coil something that's going to be de-activated upon passing initial registration emissions test so.......
JB Weld it in place? locktite thread saver....any suggestions? |
SLITS |
Oct 4 2004, 09:39 AM
JB - the finest shit on earth. It will lock it in, but I'm not to sure about removal (but then you could just drill it out). You could try some Orange Permatex RTV - it supposedly is resistant to 600 degrees, since this for the test only.
nebreitling |
Oct 4 2004, 11:41 AM
i've got a bolt j-b welded in one of my air injection ports. it's held so far...
let it cure for a long damn time... |
qa1142 |
Oct 4 2004, 11:57 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
JB Weld come in fast or slow cure
It'll fix everything but your marrage! (IMG:style_emoticons/default/pray.gif) |
JmuRiz |
Oct 4 2004, 12:20 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
QUOTE It'll fix everything but your marrage! Can't fix a broken seat adjuster (IMG:style_emoticons/default/sad.gif) |
d7n7master |
Oct 4 2004, 12:24 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Used it to repair a small crack on our boats OMC outdrive about 2 years ago. Worked like a SOB.
Still looks exactly the same & doesn't leak. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:01 PM |
