914 transmission disassembly, Step by step, so it can go back together |
bondo |
Oct 5 2004, 04:01 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I just took apart my last transmission, and I carefully documented the disassembly with notes and pictures. I did it so I could put one back together, but I might as well post it here for all to benefit from. It is not intened to replace Red-Beard's article, more to supplement it. The parts diagrams and Red-beard's article are not enough to turn a pile of parts into a transmission. (There are three similar tapered washers that are all different thicknesses, for example) You either have to just know where everything goes, or take very good notes while disassembling. I did not fully disassemble the transmission, just the most confusing parts that usually have to come off. I left a bearing race on the input shaft, and a bearing on the pinion shaft. I did not remove the differential. Without further adoo, (I don't even try to spell french) here's step one:
1. Drain the gear lube! Very important! Here's what happens when you don't: Attached image(s) |
bondo |
Oct 5 2004, 04:23 PM
Now tap the 2/3 and 4/5 shift rods into the transmission. Those are the shift rods that only stick out of the intermediate plate about 1cm. The one closest to the 1/reverse shift rod won't budge unless the 1/reverse shift rod is in the neutral position due to the way the detents work. Tapping the two shift rods engages 3rd and 5th, at the same time, locking the transmission.
Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 08:43 PM |
