914 transmission disassembly, Step by step, so it can go back together |
bondo |
Oct 5 2004, 04:01 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I just took apart my last transmission, and I carefully documented the disassembly with notes and pictures. I did it so I could put one back together, but I might as well post it here for all to benefit from. It is not intened to replace Red-Beard's article, more to supplement it. The parts diagrams and Red-beard's article are not enough to turn a pile of parts into a transmission. (There are three similar tapered washers that are all different thicknesses, for example) You either have to just know where everything goes, or take very good notes while disassembling. I did not fully disassemble the transmission, just the most confusing parts that usually have to come off. I left a bearing race on the input shaft, and a bearing on the pinion shaft. I did not remove the differential. Without further adoo, (I don't even try to spell french) here's step one:
1. Drain the gear lube! Very important! Here's what happens when you don't: Attached image(s) |
bondo |
Oct 5 2004, 05:54 PM
The input shaft parts come off in the following order:
Bearing (flatter side of the brass part towards 5th) 5.9mm thick tapered washer (flat side towards 5th) 5th gear, associated roller bearings and race 4/5 slider and hub 4th gear, associated roller bearings and race 2.5mm thick flat washer 3rd gear (flat side towards washer, ridge towards second gear) 2nd gear does not come off of the shaft, it's part of it. Attached image(s) |
Lo-Fi Version | Time is now: 14th May 2024 - 09:06 PM |
