914 transmission disassembly, Step by step, so it can go back together |
bondo |
Oct 5 2004, 04:01 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I just took apart my last transmission, and I carefully documented the disassembly with notes and pictures. I did it so I could put one back together, but I might as well post it here for all to benefit from. It is not intened to replace Red-Beard's article, more to supplement it. The parts diagrams and Red-beard's article are not enough to turn a pile of parts into a transmission. (There are three similar tapered washers that are all different thicknesses, for example) You either have to just know where everything goes, or take very good notes while disassembling. I did not fully disassemble the transmission, just the most confusing parts that usually have to come off. I left a bearing race on the input shaft, and a bearing on the pinion shaft. I did not remove the differential. Without further adoo, (I don't even try to spell french) here's step one:
1. Drain the gear lube! Very important! Here's what happens when you don't: Attached image(s) |
bondo |
Oct 6 2004, 12:22 AM
Looks like it's already in the classics.. I guess that's your second (IMG:style_emoticons/default/smile.gif) Dunno who did it. Thanks guys, I really appreciate the positive feedback.
About the pics of syncros I was thinking of adding, I decided against it because it wouldn't really add anything that isn't covered by Red-Beard's article. Besides, I don't fully understand what goes on with those brake rings and stop blocks, etc. I don't want to mislead anyone with misinformation. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:39 AM |
